Problems with my Wrx - Subaru WRX Forum
post #1 of 11 Old 07-10-2011, 07:39 PM Thread Starter
drizzy is an unknown
Hi guys,
I recently just bought an 06 wrx that has a full exhaust with not cats on it yet (But in 2 weeks im getting them put back on) with a stage 2 cluth and a turbo timer. So basically the "Check Engine" light is on but that is due to not having the cats on. Now the cruise control light is flashing on me. Well today I notice by the button to pop the hood, there was a green wire hanging lose that had been disconnected from other wire. Well i decided to connect it and I turned the car on and the cruise control light went off but then the check engine light started blinking at me. Well when this happen, the inside of my car really started to smell like gas, and then when my car was idling at a stop light, the rpms would really spike up above 1 and go up and down on its own. It almost sounded like the car was about to die but wasnt and then i didnt have the speed like i did before hooking up the wire. It was almost like I didnt have a turbo. Well I went to autozone and they told me it was ### the car wasnt getting enough air. Well when i got home i unclipped the cruise control wire again and turned on the car and the car ran fine like it should be but then it was back to the cruise control light blinking and the check engine light just on. Ive done some research but I cant find anything like this. Can someone help me out and let me know what you think it could be ### I didnt wanna pay alot of money on this car and then it just die on me.
Thanks for your guys help.
drizzy is offline
post #2 of 11 Old 07-10-2011, 08:13 PM
Did you get the code(s) read? With the cruise light/CEL light(s) on there should be codes stored that can be read and give you a place to start your looking or replacing. Have you tried getting in contact with the previous owner about the wire and what it was like that for?
post #3 of 11 Old 07-10-2011, 08:20 PM Thread Starter
Not yet im going to Subaru tomorrow but I know they will charge me alot to do it. Kinda why I was asking on here to see if anyone had a clue what it could be. Do you think maybe autozone could read the codes? Nah thats not really an option i dont think ### the car was sold to this dealer at an auction. Maybe I can ask them if they can get some info on the previous owner
** Also I just went to Autozone and they picked up the codes... They are:
P0137
P0140
P2096
Now I know these codes have to do with the exhaust system but could these be the reason why my car was acting funny today when i plugged in the cruise control and why it started smelling like gas inside the car??
drizzy is offline
post #4 of 11 Old 07-10-2011, 10:17 PM
What a min. Did you hook the two green wires up that puts the car into diagnostic mode? The very same green wires lets you "marry" a Cobb AP to your ECU?
post #5 of 11 Old 07-11-2011, 02:10 AM Thread Starter
Yea they were green right by the thing that pops the hood.
drizzy is offline
post #6 of 11 Old 07-11-2011, 05:46 AM
Ok, so not the green "test connectors" under the dash.
I'm not sure what the green wires are from under the hood.
P0137-low voltage O2 (probably the back one)
P0140-another O2 sensor issue (back one)
P2096-This is prob from the o2 sensor/cat (back one)
Put the cats back in and reset the ECU (disconnect the battery and press on the brake pedal for 5 secs to drain the remaining power) and let it sit for 30 mins.
Have you looked under the car to see if the back o2 sensor is even there ?
post #7 of 11 Old 07-11-2011, 08:17 AM
^They are the green wires, he meant by the hood release lever.
Not sure the exact procedure behind connecting/disconnecting those, but they only need to be connected when trying to read/flash the ecu.
post #8 of 11 Old 07-11-2011, 08:45 AM Thread Starter
Nah I havent looked yet but I will today. Wow so I connected the wrong wires so no wonder why the car was acting up and stuff. alright cool well ill leave those unconnected and ill wait till we get the cats back on. Thank you guys so much for your help I thought it was the car but stupid me hooked those wires up so thats the car was acting funny.
drizzy is offline
post #9 of 11 Old 07-11-2011, 10:25 AM
You didn't notice the fans cycle and all that clicking going on ?
Report back.
More than likely, you could just get a tune and be done.... Is there a tune on the car ? Or a programmer?
post #10 of 11 Old 07-11-2011, 08:54 PM
Yeah, the test connectors under the dash. Not the hood. Having them connected does make the car act crazy. The fans shut on and off a lot, clicking noises, and dash lights flashing. Just leave them disconnected. A tune should eliminate the CELs due to not having any CATs.
post #11 of 11 Old 07-12-2011, 12:58 AM Thread Starter
Yea I took it for an inspection today and they said thats what most likely will happen. Thank you guys for helping me out with this stuff ha Im new to all this so yea thanks again guys.
drizzy is offline
