Old 03-31-2008, 10:45 PM   #1 (permalink)
squirells 06's Avatar
Reputation: squirells 06 is an unknown
problem
i have an 02 wrx w/ tbe, pully's, headers,and Cobb ap v 2,and stg 2 map, i was going to work the other morning crusin 5th gear ,down shiffted to 4th to pass somebody and my car was running like it was about to run out of gas, you know like cutting off and stuff, and then a really loud back fire puff of black smoke and then it was running normal again but the cel started flashing ,so i put it in N and rolled to a stop and pulled over and sat there for a second or 2 and as soon as i put it in gear started to take off the cel went off. so i was wondering if anybody has had this problem or what it might be. Oh and the car just rolled over 100k and i am good about maintenance. apperciate the help or input.
thx
justin
Old 04-01-2008, 08:25 AM   #2 (permalink)
Longshot's Avatar
Car: 05 WRX
If you're running catless you probably just overboosted. Is the cobb map one straight from their website? The OTS maps have been known to cause a spike under their rich condition.
DTRacing Tuned
Old 04-01-2008, 02:09 PM   #3 (permalink)
yea im rtunning catless and its the map that came on the programer i dont remember if i got it on the cobb site or not, so to you it doesnt sound to major huh
Old 04-01-2008, 02:19 PM   #4 (permalink)
Longshot's Avatar
Car: 05 WRX
You should probably get an internet tune or have the car just tuned by a pro in general. It helps with those kinds of issues. You also might want to look into a 3port boost control solenoid. See if it continues when under WOT.
DTRacing Tuned
Old 04-01-2008, 02:28 PM   #5 (permalink)
kk got all that except the 3port boost soleniod ... what is that or where can i get one
Old 04-01-2008, 02:40 PM   #6 (permalink)
Longshot's Avatar
Car: 05 WRX
This is the least expensive one
GM Boost Control Solenoid - Commercial ECU Reflashes - NASIOC
DTRacing Tuned
Old 04-01-2008, 05:02 PM   #7 (permalink)
VD5505's Avatar
Reputation: VD5505 is more helpful than not
when was the last time you changed your plugs and fuel filter?? its always best to get a protune, those maps that come with the cobb are not that great of maps there just maps to get you going, i would save for a better tune. its well worth the money
Old 04-01-2008, 11:14 PM   #8 (permalink)
i havent changed the fuel filter but i did change the plugs at like 90k oh and isnt it about time for a timeing belt.
Old 04-01-2008, 11:14 PM   #9 (permalink)
Looks like im savin up for a protune then.
Old 04-08-2008, 12:03 PM   #10 (permalink)
ha found the problem, both of the passengers plugs where loose as *&%$,oh and i took my itnercooler off and the tranny mount under was miss a bolt on the tranny side of the mount ,so good thing i found all that stuff and thx for the help guys
Old 04-08-2008, 12:27 PM   #11 (permalink)
Longshot's Avatar
Car: 05 WRX
Wow im shocked the CEL didn't say on, I figure you'd get at least 1 misfire code. I'm glad you found the problem, how does it ride now?
DTRacing Tuned
