Problem with 03 WRX. - Subaru WRX Forum
post #1 of 19 Old 01-24-2009, 10:07 AM Thread Starter
Deshi's Avatar
Deshi is an unknown
Hello guys. I am in need of your help. I own an 03 WRX with 75K miles on it. That car is all stock with the exception of a short shifter.
I drove to the laundry mat night, about 2 miles from my house, really babying it shifting at 2K. When I pulled into the laundry mat parking lot and parked, I got a wiff of something burning. I sat for a minute and saw smoke comming from my hood. I poped the hood and noticed the smoke was coming from my turbo (or that area). Since it was dark, I couldnt tell for sure. There was NO oil or fluids that I could see. I didnt try to drive it back in fear of hurting something thats not allready hurt.
My question is, What do you think it could be? I am new to turbo engines so just taking a guess, I am thinking that my turbo spun a bearing or something of that affect. The car did not throw any cel's so I dont know if pluggin it in would help.
Deshi is offline
post #2 of 19 Old 01-24-2009, 10:19 AM
it could be something as simple as axel grease on the DP. I would just look around to see if any fluids are leaking in that area.
nagyhead is offline
post #3 of 19 Old 01-24-2009, 10:25 AM Thread Starter
Deshi's Avatar
Deshi is an unknown
I would think that to (my old outback blew the front diff and took out the cv) (same smell almost) But the concentration of the smoke was under the turbo heat shield. Could only see with cell phone light.
Deshi is offline
post #4 of 19 Old 01-24-2009, 10:47 AM
Your gonna have to take the heatsheild off.Could be a loose line or something.Does the smoke smell like burning oil or sweet like burning coolant.Both have a distinct color and smell when burning.Obviously in daylight you should be able to get a better look.Look under the car first thing and see if you can find a puddle.Check the oil level and coolant level next.If all seem normal,start the car and see if you can pinpoint the smoke and if anything is leaking.If it is only 2 miles away I would try to drive it home without going into boost.
dumdum is offline
post #5 of 19 Old 01-24-2009, 11:46 AM
03 CrazyTaxi's Avatar
+1 to what Dumdum has to say. You need to pull the heatshield off. My guess is you've torn your inner CV boot and have axle grease splattering on your downpipe. I've had it happen twice, the smell is like crap on fire.
03 CrazyTaxi is offline
post #6 of 19 Old 01-24-2009, 12:20 PM Thread Starter
Deshi's Avatar
Deshi is an unknown
Im still not thinking it is the cv boot because I have had that happen to me before in an Outback and that was horrible. The cabin filled with smoke and there was one hell of a trail of smoke behind the car when that happened. Thats not the case here. The smoke was billowing out from under the turbo heatshield. I cant say what color the smoke was but it didnt seem sweet smelling which leads me to believe it is an oil leak or something of the sort. Is there anything I need to check on the turbo before driving it again if it is just a oil leak? After the leak is fixed that is. Should the turbo still be ok to use of do you think it might have been starved of oil and fried something or what?
Thanks guys for your help.
Deshi is offline
post #7 of 19 Old 01-24-2009, 02:30 PM
Depending on where the oil is coming from, it might still be good. If it's coming from the bearing cartridge, you might be looking at a new turbo.
post #8 of 19 Old 01-24-2009, 04:05 PM Thread Starter
Deshi's Avatar
Deshi is an unknown
If that is the deal, what do you think about a stock motor running a Deadbolt TD05H-16G to replace the factory turbo?
Deshi is offline
post #9 of 19 Old 01-24-2009, 04:35 PM
/\ There is a ton of information on this site about upgrading turbos,especially that one...........
dumdum is offline
post #10 of 19 Old 01-26-2009, 08:28 AM
isd_intrepid's Avatar
isd_intrepid is an unknown
Send a message via Yahoo to isd_intrepid
I'm willing to lean towards a turbo seal has gone out.
AND
Deadbolt resells Blouch Turbos
isd_intrepid is offline
post #11 of 19 Old 01-27-2009, 05:11 PM Thread Starter
Deshi's Avatar
Deshi is an unknown
I hope the turbo is still good just for the fact that I cant really afford a bigger turbo and supporting mods right now. I guess if the turbo is bad, I will just go with a Deadbolt Monster TD04 just for the fact it will make a tad more power but does not require any other mods to be done. I am not checking it out for the shear fact that I am in no way experienced enough to diagnose this kind of issue. I should hear back from the mechanic today as to what it is.
Deshi is offline
post #12 of 19 Old 01-28-2009, 06:59 PM Thread Starter
Deshi's Avatar
Deshi is an unknown
This will show that I really have no idea how to diagnose a turbo issue. I took my car to a mechanic and they said there is nothing leaking from the turbo but they did find antifreeze on the block but after a pressure test, nothin was leaking from the system??? Any ideas guys? I cant seem figure this one out either.
Deshi is offline
post #13 of 19 Old 01-28-2009, 08:22 PM
boo-key's Avatar
Try another mechanic.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #14 of 19 Old 01-28-2009, 09:28 PM
^^ no kidding. if there is coolant on the block, its leaking from somewhere.
nagyhead is offline
post #15 of 19 Old 01-29-2009, 04:21 PM Thread Starter
Deshi's Avatar
Deshi is an unknown
Ok, I am really starting to get pissed with these guys. I was told that they would have it figured out by monday afternoon. Today is now thursday and they are telling me something else. They say they found a fuel leak(which is known to happen with this vintage rex) and no mention of the antifreeze this time around. They are not calling me back like they say they will. I need my car back by monday because iv had a trip planned for awhile and I took my car to them because they said they could have it done by this week. I feel like they are putting me off. I hate mechanics in my town. They all suck.
Deshi is offline
