Help, i have an impreza wrx bugeye 01 plate and just reciently the power steering wont work unless the engines being reved, it works fine when your driving around but assoon as the cars stopped the steering wont work stupidly stiff bit tricky on car park n tight spaces ideas any one??
what does your fluid look like? did you check your belts? worse comes to worse go to a parts store and get a new pump they are pretty cheap and very easy to put in.
I have checked the fluid level thats fine ill check the belts first then go from there it could be slipping as its wierd that it works fine when the engines revved thanks for that!
Your pump is prob going out, and by your revving your engine it is spinning the pump faster so it might be moving the fluid a little bit more, i think a new pump is like $100
