-   -   PO224 wastegate (http://www.wrxtuners.com/forums/f72/po224-wastegate-41514/)
Nathan21 11-19-2013 07:40 PM
PO224 wastegate
So I was getting on it pretty hard passing some cars hitting about 5500rpm in 3rd gear and then threw this CL code PO224 wastegate? This is the 2nd time. First time I was 2nd gear at 5500 in crazy dusty area. Need help, already cleared the code but I figured 2nd time it happen I should ask
turmic 11-19-2013 08:25 PM
Were you flooring it? Because that's a overboost code.
psinuse 11-19-2013 08:32 PM
What mods do you have on the car?
Nathan21 11-19-2013 10:02 PM
Cat back and intake that's it, and no I was on it hard, I am going to load a lwg map tomorrow and see how it does
Nathan21 11-19-2013 10:09 PM
Also I will run a log on my way to the office before I do the lwg and investigate what I get and post it as well tomorrow
BLAZE2099 11-20-2013 05:39 AM
Take off the BOV!!!
ROFLROFLROFLROFLROFL
Nathan21 11-20-2013 09:00 AM
Alright guys, here is my log before I change to lwg but it seems to me everything seems perfect?
I won't be changing over on this till I get yall's opinion
C:\Users\nathan\Downloads\datalog1.csv
boo-key 11-20-2013 12:10 PM
549 Attachment(s)
cant click the link
Nathan21 11-20-2013 12:41 PM
Copy n paste?
Haw1es 11-20-2013 01:11 PM
Yeaaaa, so that's a link to the file on your computer. It needs to be hosted ie google docs.
Nathan21 11-20-2013 01:56 PM
1 Attachment(s)
try this
Haw1es 11-20-2013 02:28 PM
That's better ��
Nathan21 11-20-2013 02:36 PM
Everything looks good to me honestly
Doesn't look like I should run a lwg map
boo-key 11-20-2013 05:48 PM
549 Attachment(s)
I would try to avoid flooring it at low rpm's in highger gears. That is sometimes a cause for overboosting. Just downshift if needed.
thekamikaze kid 11-20-2013 05:59 PM
b4 u change yer map u should send yer map to cobb. and c if they would recomend that. I was gonna do the same thing and they strongly advised me not to. is your car stage 1?
