Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 02-15-2007, 07:16 PM   #16 (permalink)
Reputation: wrxsm is an unknown
there dont seem to be any boost leaks all hoses are on from filter to throttle body any other ideas im lost
Old 02-15-2007, 07:43 PM   #17 (permalink)
Timeslip: 9.999 @ 105.48
Club Region: SoCal
Reputation: wcjuggalo is an unknown
check the hard to reach hoses under the i/c? is it a used turbo? why did you replace it to begin with?
Old 02-15-2007, 08:01 PM   #18 (permalink)
the old turbo wouldnt make any boost at all zero boost
Old 02-16-2007, 01:41 AM   #19 (permalink)
Reputation: WRXKidid775 is more helpful than not
have you reset your ecu? sometimes something that simple will help.
if its running super rich and blowing black smoke maybe you have a fuel issue, leaky injector or something like that.
is it throwing any codes? even if it isnt take it to autozone and have them check anyways, sometimes the ecu will have a code stored but not trigger a cel.
if the ecu reset doesnt work and there are no codes id take it to a shop and let them look at it.
you might have gotten a lemen turbo, that would suck. check the bcs it might be weird too, the subaru bcs is retarded, its right above the airbox.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
Old 07-29-2008, 11:33 AM   #20 (permalink)
Squamr's Avatar
Car: 04 WRX
Reputation: Squamr is an unknown
Does any body know what the problem ended up being? I'm having a similar problem.
-only making 7 psi. but when we put manual bc on it we got 12 psi.
-we checked the voltage on the boost selenoid and it seems ok. (i might try a new one though)
-getting a code for running rich.
-getting intermitent misfire codes on different cylinders.
-sometimes it won't go past 3k rpm, sometimes it's 5k rpm.
-black smoke puffs at upper rpm's
-sometimes it will barely idle.
-we tried a new bov and it made no difference.
-tried a Cobb Ap w/ stage 1 and it made no difference.
-cleaned the MAF.
-checked for air leaks.
I'm putting in new plugs tonight and checking the coils.
Old 07-31-2008, 06:26 AM   #21 (permalink)
Is this the way you purchased your car or did it just start running like this?Need a full list of mods.
Aarg matey!
ECU Pirated by RomRaider
Old 07-31-2008, 06:37 AM   #22 (permalink)
Longshot's Avatar
Car: 05 WRX
I put a few comments in your thread that you started. List your mods also as dumdum said. Just diagnose your problem in one thread.
DTRacing Tuned
Old 07-31-2008, 08:21 AM   #23 (permalink)
Squamr's Avatar
Car: 04 WRX
I moved it over to this other thread.
Running really bad and can't figure it out...
