Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 02-12-2007, 04:10 PM   #1 (permalink)
Reputation: wrxsm is an unknown
Exclamation Please HELP!! (I'm an idiot)
I recently replaced the stock turbo in my 03 WRX with another, and after installing it, you could hear the turbo spool but it doesn't seem to be building boost. Upon reaching 3-4 RPM's the car starts to hesitate really, really bad. The car doesn't go above 80 mph...infact the faster I go the slower it accelerates. I've been told over and over its a leak in the vaccuum line, and I've checked my work 6 or 7 times now, but I still cannot find the problem.
Trying to get this shit fixed so I can get down to Florida ASAP. Please help immediately!
Captain Out.
Old 02-12-2007, 04:29 PM   #2 (permalink)
ohhNOwrx's Avatar
Reputation: ohhNOwrx is an unknown
Did you replace it with a stock turbo?
Old 02-12-2007, 06:35 PM   #3 (permalink)
mxboy15u's Avatar
Reputation: mxboy15u is an unknown
How is it tuned? What are your other mods?
Old 02-12-2007, 11:42 PM   #4 (permalink)
Reputation: WRXKidid775 is more helpful than not
i think he replaced it with a stocker. check the waste gate actuator arm it might be too loose.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
Old 02-13-2007, 01:00 AM   #5 (permalink)
yeah its another stock
Old 02-13-2007, 01:06 AM   #6 (permalink)
waste gate actuator arm seems to be all right....mods include:
headers, up pipe, downpipe, exhaust,blow off valve, turbo timer, intake, and boost controller.
called subaru and they said it might be the first cylinode on the passenger side. guess its an acutator of some sort?
or they said it might be the vaccuum line from the cylinode to the turbo...but it still looks okay to me.
any other ideas?
Old 02-13-2007, 01:53 AM   #7 (permalink)
Black05WRX's Avatar
Car: 05 WRX
Reputation: Black05WRX is an unknown
Boost leak. Have you checked for any? If your leaking your not going to build pressure.
Looking it over, I dont know how you can really test for a vac leak, I know on the DSM's you just made your own to build pressure and listen for leaks.
Another way to do it, is get some soapy water, turn the car on and see if you can see any air come up while at idle. Also do you have a guage? Is it reading normal vac?
Old 02-13-2007, 01:59 AM   #8 (permalink)
i agree with black05 boost look probably. check your vac line from the bcs for a restrictor pill, that might be missing as well and could cause boost to act funny
Robby
02 rex is gone.
Evo is gone :(
Now I got nothing.
Old 02-13-2007, 02:02 AM   #9 (permalink)
Black05WRX's Avatar
Car: 05 WRX
Its what I have experince with my DSM's each time it was something stupid as something not being on correctly.
You never have truly worked on a car till you do something stupid and simple
Old 02-13-2007, 07:52 AM   #10 (permalink)
You aparently have an aftermarket boost controler.Subaru was talking about the factory solenoid you are probably no longer using....
Aarg matey!
ECU Pirated by RomRaider
Old 02-13-2007, 11:40 AM   #11 (permalink)
Car: 04 WRX
Reputation: shamrock is an unknown
Get rid of the boost controller, it dosent help. More harm than good
_Ryan_
2004 Wrb "BUGEYE"
http://www.misubie.com/
Old 02-15-2007, 05:33 PM   #12 (permalink)
checked for vaccum leak holds vaccum good at idle when in nuetral car will rev fine but in a gear doesnt want to get above 2000 with out fighting runs rough in gear while black smoking bad back fires from time to time top speed 70 today any more ideas anyone
Old 02-15-2007, 07:00 PM   #13 (permalink)
Reputation: Kjott21 is known to be trustworthy and helpful Kjott21 is known to be trustworthy and helpful Kjott21 is known to be trustworthy and helpful
It sounds like a boost leak to me too. Check all the hoses from the turbo to intercooler and intercooler to the throttlebody. Also make sure that you got the turbo inlet hose on too. It will cause issues if you're pulling unmetered air into the system too.
Old 02-15-2007, 07:44 PM   #14 (permalink)
Timeslip: 9.999 @ 105.48
Club Region: SoCal
Reputation: wcjuggalo is an unknown
what kid of blow off valve are you running. i had the same problem once and my bov cam apart. some aftermarket ones swivel for clearence, and the set screw comes lose causing a boost leak.
Old 02-15-2007, 08:12 PM   #15 (permalink)
there was a blitz on there but too everything back to stock to help eliminate problems so now there is a stock blow off valve
