Old 05-12-2008, 09:53 PM   #1 (permalink)
02Rexwag's Avatar
Reputation: 02Rexwag is an unknown
Send a message via AIM to 02Rexwag
Please help! Check engine code P0171
Hello, I dont usually post due to trying to research all I can first but I need this info asap! My problem is that my wrx threw a P0171 system too lean (Bank 1) Check engine light several minutes after I almost stalled at a traffic light. And before the almost stall the car was sputtering. I have been having a series of problems prior to this including a max boost psi of 8 and slow acceleration. My rex is an automatic with 107,000 miles. And I have colder plugs which were a bad recommendation by a friend and will be removed as soon as I can and replaced with originals. Thanks for any and all comments!!!
Joe
2002 WRX Wagon
Joe
I hear imports!
Old 05-13-2008, 08:45 AM   #2 (permalink)
Longshot's Avatar
Car: 05 WRX
its probably the plugs. Get stockers in there with the right part # and reset the ecu and then see if the CEL comes back.
DTRacing Tuned
Old 05-13-2008, 11:09 AM   #3 (permalink)
WRXtreme's Avatar
Reputation: WRXtreme is more helpful than not
Check the MAF to see if its clean, that may be the problem.
Old 05-13-2008, 01:14 PM   #4 (permalink)
VD5505's Avatar
Reputation: VD5505 is more helpful than not
+1 to changing the plugs back to OEM, and cleaning that MAF, its a good idea to put a new fuel filter on there as well, they are cheap enough, unless you have just changed it.
Old 05-13-2008, 09:53 PM   #5 (permalink)
02Rexwag's Avatar
I will definetly change the fuel filter and plugs! And I will check the MAF sensor and then go from there! Thanks for the replys!!
Joe
I hear imports!
Old 05-13-2008, 10:22 PM   #6 (permalink)
Car: 04 WRX
Reputation: dak287 is an unknown
+1 fuel filter +1 plugs +1 injector cleaner.. i would also pull the vaccum hoses off the turbo and cheak for cracks and leaks + inspect for oil in the vac lines..
