peak boost too high? - Page 2 - Subaru WRX Forum
 2Likes
post #16 of 20 Old 11-08-2013, 08:45 AM
NeverSummer's Avatar
Originally Posted by sk8rzch View Post
You think something is wrong? The guage hits 16 psi so fast you can barely see it because it changes right away. Would would you think is wrong? Oh I forgot to mention, previous owner put a k&n air filter in the stock air box. Would that matter?
Get rid of the k n filter if your not tuned for it
Sent from AutoGuide.com App
NeverSummer is offline
post #17 of 20 Old 11-08-2013, 09:33 AM
Sounds like a possible boost leak?
post #18 of 20 Old 01-14-2014, 01:21 PM
Subiekid14 is an unknown
Originally Posted by DJ8371 View Post
Quick question about boost....... I just bought a 2007 WRX and the only Mods I know of is a HKS exhaust (Just From Axle back, not full system) and a stock intake with stock filter. The issue Im seeing and Im not sure it even isa issue but Ive never had a turbo'ed car. It seems when your pushing higher RPMs Maybe between 3-5000 and genrally in 2-4 gear Ive notice that while holding the gas pedal in one postion that my boost varies up and down with no variation to the pedal. The pressure just goes up and down up and down, should it not be steady to a certain extent? Only variying when you apply more gas or less gas pedal pressure??? Please help Ive had the car a week and it concerns me. I cant find a thread pertaining to this issue, thanks in advance...
Ok haha i know your new to turbo cars so here it goes, turbos produce power off the exhaust gases that flow through it, press on the pedal a little and the gases will flow, press it to the ground and the gas will flow faster which spools it faster and faster therefore increasing boost, in a nutshell, how you press on the accelerator is what makes the engine go faster and the turbo produce more boost sorry for thread jack :/
Subiekid14 is offline
post #19 of 20 Old 01-15-2014, 11:17 AM
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
do you have a boost gauge? or an Access port?
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #20 of 20 Old 01-15-2014, 09:04 PM
General-Leo's Avatar
General-Leo is more helpful than not
I have a 13 wrx which in which all the stock parts are the same from what I understand (someone correct me if I am wrong please) and when I put JUST the K&N filter in it started running like crap. def replace with the stock filter until you are ready for a full intake.
sorry NeverSummer I didn't see your post until after I posted.
General-Leo is offline
