peak boost too high? - Subaru WRX Forum
 2Likes
post #1 of 20 Old 11-02-2013, 12:35 AM Thread Starter
sk8rzch is an unknown
I Have A Bone Stock 09 Subaru Wrx, And Was Wondering How Much Boost Spike Is To Much. My Boost Spikes To 16 Psi Then Drops To A Stead 13.5 Psi. I Was Told By A Local Shop That The 16 Psi Was To High. I Am Getting Fuel Cut Out At About 4200rpm. Thats When I Usually Get A Quick 16 Psi Spike Then A Hesitation. Does That Seem To High?
Sorry about the caps, new phone trying to figure out how to use it.
sk8rzch is offline
post #2 of 20 Old 11-02-2013, 03:29 AM
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
Actually I hit 16 spike today on my way home! Interested to see what's said
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #3 of 20 Old 11-02-2013, 06:50 AM
Premium Member
arewmors's Avatar
Typically a bone stock wrx psi factory rating is 14.2 psi so for a stock tune that's probably a little high. They usually say +/- 1 psi.
Nathan hit 16 because he is tuned at stage 1 which the tune is for about 16 so he is right there with his boost.
Andy - 12 WRB WRX
Tuned by Innovative Tuning
294 AWHP / 311 TQ
arewmors is offline
post #4 of 20 Old 11-02-2013, 07:37 AM Thread Starter
You think something is wrong? The guage hits 16 psi so fast you can barely see it because it changes right away. Would would you think is wrong? Oh I forgot to mention, previous owner put a k&n air filter in the stock air box. Would that matter?
sk8rzch is offline
post #5 of 20 Old 11-02-2013, 07:40 AM
Premium Member
arewmors's Avatar
Possibly. The maf sensors on the 08+ are pretty sensitive. I'd get rid of it and get a stock air filter IMO.
Andy - 12 WRB WRX
294 AWHP / 311 TQ
arewmors is offline
post #6 of 20 Old 11-02-2013, 08:37 AM
Premium Member
the RIOT act's Avatar
This has to go ASAP! Any mod to the intake on an 08+ is gonna cause problems.
Sent from AutoGuide.com App
arewmors likes this.
Brandon - 13' SWP WRX Sedan
the RIOT act is offline
post #7 of 20 Old 11-02-2013, 08:44 AM Thread Starter
Well im going to reset my ecu first. If it doesnt fix it im going to buy the stock air filter and put it in. Thanks guys!
sk8rzch is offline
post #8 of 20 Old 11-02-2013, 09:02 AM
Is it cold up there in Pittsburgh?
post #9 of 20 Old 11-02-2013, 03:06 PM
Premium Member
Nathan21's Avatar
Thanks Andy, I didn't know going stage 1 would raise my boost?! Had me a little worried!!!
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #10 of 20 Old 11-02-2013, 03:19 PM
Premium Member
arewmors's Avatar
When you go stage 2 it ups your boost again too
Andy - 12 WRB WRX
294 AWHP / 311 TQ
arewmors is offline
post #11 of 20 Old 11-02-2013, 05:53 PM Thread Starter
Its been in the up 40s to low 50s here in puttsburgh
sk8rzch is offline
post #12 of 20 Old 11-02-2013, 06:01 PM
Premium Member
Nathan21's Avatar
What kinda boost should you expect from stage 2
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #13 of 20 Old 11-02-2013, 07:20 PM
Premium Member
arewmors's Avatar
18 psi on the cobb ots map
Andy - 12 WRB WRX
294 AWHP / 311 TQ
arewmors is offline
post #14 of 20 Old 11-02-2013, 07:29 PM Thread Starter
Ok guys I just ran to the store to grab a couple things. It was 47 degrees out and raining. I opened her up a couple times and never hit 16psi peak boost. The peak I got was 15 psi then it was steady at 13.5 psi. I did get hesitation though. And it was at 10 psi when It happened. So I doubt it is fuel cutout. Would hesitation be from just the cold weather?
sk8rzch is offline
post #15 of 20 Old 11-08-2013, 09:05 AM
DJ8371's Avatar
DJ8371 is an unknown
Quick question about boost....... I just bought a 2007 WRX and the only Mods I know of is a HKS exhaust (Just From Axle back, not full system) and a stock intake with stock filter. The issue Im seeing and Im not sure it even isa issue but Ive never had a turbo'ed car. It seems when your pushing higher RPMs Maybe between 3-5000 and genrally in 2-4 gear Ive notice that while holding the gas pedal in one postion that my boost varies up and down with no variation to the pedal. The pressure just goes up and down up and down, should it not be steady to a certain extent? Only variying when you apply more gas or less gas pedal pressure??? Please help Ive had the car a week and it concerns me. I cant find a thread pertaining to this issue, thanks in advance...
DJ8371 is offline
