Old 07-13-2008, 12:27 AM   #1 (permalink)
03 CrazyTaxi's Avatar
Reputation: 03 CrazyTaxi isn't as helpful as most
P1446
Ok, so I searched the forums for this but haven't found an answer.
Here's what happened. I installed a catless downpipe on a friends 02 WRX, flashed in a basic stage 2 tune through OpenECU. Took it out for a drive, CEL came on for P1446.
What is it, what could cause it and can I just tune it out?
Old 07-13-2008, 10:38 AM   #2 (permalink)
b7g
b7g's Avatar
Reputation: b7g is an unknown
fuel tank sensor control valve circuit low... I am not sure if it is caused by your downpipe install--you have to make sure all the wires/connectors are intact. If everything is fine, then it is the sensor. The sensor is a pain to get to, so it might be easier to turn it off in romraider. But I just looked at an 02 and 03 maps and p1446 is not listed...
drive = freedom
Old 07-13-2008, 11:05 AM   #3 (permalink)
Reputation: dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to
Try flashing another stage 2 map or flashback to stock and see if the CEL comes back.Also double check and make sure it's the right map and always use a map that is of the latest Subaru revision.For the 02 it is the A4SGE01C (AF426)
Aarg matey!
ECU Pirated by RomRaider
Online
Old 07-13-2008, 01:53 PM   #4 (permalink)
Wouldn't happen to have a link to that tune? On Enginuity, I have the ability to disable it in Enginuity but I'd rather do this the right way rather than a quick fix. My buddy will probably be bringing the car over tonight or tomorrow so any help is appreciated.
Old 07-13-2008, 07:19 PM   #5 (permalink)
You shouldn't have the ability to disable it for an 02.The 02 WRX does not have that sensor.The 03 does.Sounds like you might have the wrong ROM.
Scoobypedia | Trusted knowledge for everything Subaru | Knowledge / ECU Version Compatibility List
RomRaider • View forum - WRX Base Maps
OSecuroms & XPT Tuning • Login
Aarg matey!
Online
Old 07-13-2008, 07:39 PM   #6 (permalink)
b7g
b7g's Avatar
...so that's why it's not listed...
drive = freedom
Old 07-13-2008, 09:33 PM   #7 (permalink)
Yeah, I did have the wrong one. Didn't realize it at first but I went ahead and changed the stock map (saved a copy first) to what I needed. Soon as he gets here, I'll reflash him. He'll be pretty happy about that.
Also, downloaded ROMraider 0.5.0 since Enginuity is no more.
