Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 08-22-2009, 05:46 PM   #1 (permalink)
Club Region: Gulf Coast
Reputation: groovybaru is an unknown
P0172 code, too much fuel?
Just bought my 03 Wrx a few days ago. CEL came on yesterday, code read P0172
The car runs fine under a sustained speed, but when shifting and releasing the gas it seems the engine is not receiving fuel and kills itself. It has only done this once, but even in idle it feels as if there is a shortage of fuel running to the engine.
But isn't P0172 "system too rich"?
Previous owner had put an aftermarket bov on and I plan on replacing it with a factory bpv from Subaru. (Any suggestions for finding them cheap online would be helpful )
Any help or suggestions are appreciated.
-Russ
Old 08-22-2009, 07:14 PM   #2 (permalink)
Its possible the aftermarket BOV is leaking but without any other diagnosis from you (fuel pressure check,vacuum leak check,mod list,datalog) its a shot in the dark without actually seeing the vehicle. You could find a used stock BPV on NASIOC's classifieds probably.
Aarg matey!
ECU Pirated by RomRaider
Old 08-23-2009, 08:41 AM   #3 (permalink)
iaff474's Avatar
Reputation: iaff474 is an unknown
Send a message via AIM to iaff474
My cel code was from my IACV. It was bad and when replaced no more CEL's.
Cheapest I could find was Chapmans. Find subiegal on nasioc she can help with buying it.
287 hp and 257 lb-ft of torque
Old 08-24-2009, 12:25 AM   #4 (permalink)
Thanks for the help so far.
I have one more question, when you turn the engine on and release the handbrake, are your headlights suppose to come on?
Old 08-24-2009, 12:31 AM   #5 (permalink)
If the headlight switch is already on, yes your lights should come on. I take it yours dont?
Old 08-24-2009, 09:15 AM   #6 (permalink)
wagonracer's Avatar
Timeslip: 9.999 @ 92.412
Reputation: wagonracer is known to be trustworthy and helpful wagonracer is known to be trustworthy and helpful wagonracer is known to be trustworthy and helpful
Yes, daytime running lights come on when brake is released
Old 08-24-2009, 01:22 PM   #7 (permalink)
Ok, thank you. First time suby owner so I'm still a little disoriented about the car.
Update:
-Sometimes when I accelerate hard and then let off the the throttle, the car dies..?
Faulty fuel injector?
-CEL light went off for about 35miles then came back on.
-It also seems to have been some half-a$$ wiring job under the hood, there are independent wires running from my battery, to a fuse, and then to somewhere behind my front end. I haven't gotten a chance to look at it yet because of work and school, but from a quick view earlier it looked it was wiring for my headlights and/or foglights?
Old 08-25-2009, 08:36 PM   #8 (permalink)
Update:
That would probably be the BOV's fault. It's not set right or is not functioning properly.
Aarg matey!
Old 08-27-2009, 11:02 AM   #9 (permalink)
Update:
-Ordered a factory BPV, should be here in a few days.
-I pulled off the aftermarket BOV and the compression spring on the inside had about 14 washers stacked behind it. Is that normal..? I pulled them out and put the BOV back on, but then the seal wasn't closing all the way when I was in idle. So I put the washers back in and it seems to be closing and opening with no problems. But I did notice that when I hit the gas at a decent acceleration, there is a very loud air noise coming from the engine bay that I have never heard before. I also noticed I forgot to put the oring back in the BOV, could that be the reason I'm hearing the noise?
Old 08-28-2009, 01:44 AM   #10 (permalink)
Timeslip: 9.999 @ 101.26
Update:
Yes
Old 08-28-2009, 02:19 PM   #11 (permalink)
Is it possible I am flooding my engine with fuel?
.. and if so what do I need to do? tune? injectors?
Old 08-30-2009, 08:15 PM   #12 (permalink)
You need to get rid of that BOV first before doing anything else.
Aarg matey!
