P0171 - Subaru WRX Forum
post #1 of 6 Old 11-05-2009, 08:54 PM Thread Starter
goodboyWRX's Avatar
goodboyWRX is an unknown
P0171
Hey guys, about once a week now if I let my car idle for a few minutes it'll sputter for a second and almost stall and then return to normal but throw a code- P0171 system too lean (Bank 1). After researching a little I think I'm going to try new plugs, just wanted to see what you all thought. I haven't done anything recently to the car that would affect it really. All I have done is a TBE, Cobb SF intake, and an AP running the OTS stage 2 map. Thanks.
goodboyWRX is offline
post #2 of 6 Old 11-05-2009, 09:12 PM
allvolwrx's Avatar
allvolwrx is more helpful than not
It could be but not limited to MAF, ignition problem, vaccum leak, injector problem, or o2 sensor. I would start with the most simple thing like the vaccum lines. Go through the whole engine bay carefully and make sure they arent broke, loose, or cracked. Then start checking yhe other things.
allvolwrx is offline
post #3 of 6 Old 11-06-2009, 09:40 AM
That's your problem... You're running the COBB Stage II map with a cold air intake if I read that correctly. The OTS stage II from COBB says just a TBE, an intake will cause it to run too lean. Unless you have a map that takes the intake into account I would put the stocker back on and see if that fixes it, then get a map that works with the intake.
post #4 of 6 Old 11-06-2009, 11:35 AM
Not true. He says he is running the Cobb intake. Which is just like stock. Same ID, everything, just able to hear the intake and turbo noise more. If you email and ask Cobb about this, they will tell you its fine also (I know this because I contacted them before installing it). When I was tuned with my 20G my tuner treated the Cobb intake as if it were stock. And I ran the Cobb TBE, Cobb SF intake, and the AP OTS stage 2 map for just over a year with no issues.
post #5 of 6 Old 11-06-2009, 11:46 AM
Good to know... Thanks for the correction
post #6 of 6 Old 11-06-2009, 11:50 AM
No problem. Im just putting that out there so people know. I have been through some of this before. And I try and do the best research on my own before asking. Just putting out what I know in hopes it will help others.
