Overheating after clutch install. Help! - Page 2 - Subaru WRX Forum
post #16 of 20 Old 05-07-2011, 11:15 AM
To make sure the coolant is running through it as that's how the heater gets the heat, it's basically a heat exchanger with the engine coolant...
I don't know how common it is for air bubbles to get stuck in there but it couldn't hurt to run. I always do it.
post #17 of 20 Old 05-07-2011, 12:25 PM
I have no idea why my car is over heating. It just got a brand new radiator installed. I just replaced the thermostat and the water pump and after about 5mins of driving it over heats. The top radiator hose is scolding hot while the bottom is cold(thats normal but not if its over heating right?) also the radiator itself is ice cold. I have tried burping the system although i dont know if i did it right. If i get a coolant flush that should get rid of all the bubbles if there are any correct?
Sethsbiz is offline
post #18 of 20 Old 05-07-2011, 03:42 PM
^^ Correct.... Did you run water thru the radiator prior to the install ?
Have seen lots of crud come out of new radiators in the past.... Hell... even packing peanuts...
Just sayin
post #19 of 20 Old 05-09-2011, 08:25 PM
So just a quick update the car is NO LONGER over heating. The guys when they put the radiator in filled the radiator up almost 2 gallons shy of what should have been. So like we thought there was a big air pocket and it no longer over heats.
Thanks everyone
Sethsbiz is offline
post #20 of 20 Old 05-10-2011, 10:59 AM
jonathang's Avatar
I believe that the coolant runs through the heater core at all times. There is no valve. Turning on heat just directs air through the core and into the cabin, it does not affect coolant flow, so this is unnecessary and just makes you sweat.
jonathang is offline
