Over boosted again - Subaru WRX Forum
post #1 of 29 Old 01-25-2010, 08:16 AM Thread Starter
mfarnham's Avatar
Over boosted again
A few weeks ago, my car over-boosted I believe. I was accelerating when my car had a momentary lose of power and then a CEL came on. I'm not sure what the exact code was, but my dealership said I needed a new boost control solenoid. So a week ago, they replaced it; my car was under warranty. Now today, I was getting on the highway and the same thing happened. It felt like the engine stuttered or misfired as I was accelerating, and a CEL came on again.
I am going to check the code later, and then I will get you guys some more information. I just wanted some advice in the meantime. If my car really did over-boost again, does this mean I need to replace my boost control solenoid again? Or will I be fine to just clear the code?
P.S. I know that I can solve this issue by installing a good 3-port boost controller, but I don't have the money for it. I would have to buy the boost controller, an AccessPort, and pay for a tune.
Thanks for the help!
mfarnham is offline
post #2 of 29 Old 01-25-2010, 12:08 PM
To me, I would take the DP and intake off until you can afford to get tuned... That may be the cause of your problem since you're running stock maps on a Stage II setup. At least swap out the DP and see if that clears up the issue.
post #3 of 29 Old 01-25-2010, 02:17 PM Thread Starter
mfarnham's Avatar
I probably should have clarified some stuff. My car is tuned. I bought it as is. I just didn't get the AccessPort that the previous owner had.
mfarnham is offline
post #4 of 29 Old 01-25-2010, 03:33 PM
Gotcha...That was my only idea.
post #5 of 29 Old 01-25-2010, 03:48 PM
Well, if the previous owner un-married the AP. Then you would be un-tuned. Do you know if he un-married the AP? If he did...don't get on the car until it's tuned. Is your Cobb DP catted? If so, its not going to hurt a lot of things. But getting on it...is going to constantly throw your Solenoid CEL, especially if it's un-married. If the previous owner didn't give you the AP and left it married to your ECU then that's be plain dumb on his part. I ran the Cobb catt'd DP for a week until I got my original protune. But, my tuner told me to not get on it, until it was protuned.
post #6 of 29 Old 01-25-2010, 03:56 PM
blk05WRX's Avatar
Yeah, this car doesn't sound tuned to me. Or, if it is, it's not tuned correctly. I would get a new Cobb AP, or take it to a tuner.
2005 WRX Cobb Stage 2
2009 Outback
blk05WRX is offline
post #7 of 29 Old 01-25-2010, 04:14 PM
Open source tune will be cheaper for you, just find a good tuner in your area that people recommend.
sfelix818 is offline
post #8 of 29 Old 01-25-2010, 08:13 PM Thread Starter
mfarnham's Avatar
The CEL code is PO244.
I don't know if the AP was unmarried. I bought it from a dealer, and the previous owner lived in Texas. I have had the car for 5 months now and never had any problems until now.
Do you need an AP to get an open source tune?
mfarnham is offline
post #9 of 29 Old 01-25-2010, 09:23 PM
If the car is still married to the AP and you dont have the AP anymore the ECU is "locked". I dont think even an opensource tune can be done like that. The code you threw is kind of common even with the OTS Cobb Stg2 map. I threw it several times at that stage. What gear is this happening in? Its very common to happen when trying to accelerate hard in 5th gear. If that is the gear, down shift then accelerate and you should be alrite.
post #10 of 29 Old 01-26-2010, 08:33 AM Thread Starter
mfarnham's Avatar
I has happened twice in 5th, and once in 4th. So i can just clear the code and I'll be good, or do I need another wastegate solenoid?
If my ECU is "locked" does that mean I can't even buy my own AP now, cause it won't be able to work with my car?
mfarnham is offline
post #11 of 29 Old 01-26-2010, 02:09 PM
That's a worse case scenario. That your ECU might be "locked". Its going to be a pretty decent hassle. But, i'd hardly doubt someone would leave it married. If it is locked, Cobb might have a resolution for you. It might require a tuner to unlock it. But, i've never heard anyone having that issue or stating what they did to correct it. But, you'd probably have to go to a Cobb certified tuner in your area to fix it.
If your DP is catted. You wouldn't notice it until lately. Cold weather and really getting on it in 5th and 4th. Especally if your under 3 rpm and doing hard accleration. Its going to spike and give you the CEL.
Edit: I'll contact my tuner to see what he has to say. My tuner is Cobb certified.
post #12 of 29 Old 01-26-2010, 02:20 PM Thread Starter
mfarnham's Avatar
Thanks a lot Kirt!
Do you guys think I should contact my dealer and see if they want to replace my wastegate solenoid again, or just clear the code and forget about it?
mfarnham is offline
post #13 of 29 Old 01-26-2010, 02:30 PM
Clear it and forget about it. Its going to keep happening until you can get a better tune. The 3 port BCS really helps too. Because its more of a wastegate issue then a tune issue and the 3 port can lower your wastegate duty cycles. Which that requires a protune anyways....unless you really know what you're doing. The easiest way to know if its married or not. Would be to try and marry a new AP to it. If it won't marry to the new AP, it's "locked" or married to the old AP. Which Cobb and probably a Cobb certified tuner would have to resolve that issue. I'm still waiting to hear back from my tuner. READ: At any rate...a good tuner should be able to see if you have any tune loaded on your ECU or if it's locked.
Btw, Josh just told me a good point. You might need a AP anyways just to unlock it...depends on how/what they need to load a unlocking code to your ECU. Again....if it's even locked. You won't know unless you have it checked out.
Edit: My tuner said to call Cobb if it is locked. You might need to get a AP that has your VIN programmed into that. That's another thing Josh informed me that would allow a new AP to work with your ECU. Which you'd have to call Cobb and order that AP directly from them.
post #14 of 29 Old 01-26-2010, 04:41 PM Thread Starter
mfarnham's Avatar
Thanks so much Kirt. You've been wicked helpful.
I came out of school today, and the CEL was gone. Is it possible for a code to clear itself?
mfarnham is offline
post #15 of 29 Old 01-26-2010, 07:44 PM
The Code will still be there. Just not the light. Kirt shared what info I gave him because of an issue I had with my AP. My AP completely stopped working (it had a bad processor or something). I called Cobb got the information I needed, sent in the AP, and got a new one with my cars VIN in it and it plugged right in and worked like nothing was wrong. Best bet like Kirt said is to get in contact with Cobb ASAP.
Kirt thanks so much for getting this info out, appreciate.
