Ok! I have two PROBLEMS !! and i need some help from all you guys!!!!!!!!!!!!!!!!!!!! - Subaru WRX Forum
post #1 of 24 Old 06-09-2009, 09:17 PM Thread Starter
alexxxphilly is an unknown
Send a message via AIM to alexxxphilly
I just got my subaru so i dont know that much of how they act!
1- i put gas today and 2 mins later pop!!! "check engine" came on! yes i used cheap 87 could that be the problem?
2- and most important!! :
my speedo dont work. at all. so i have to change it. can i buy a 04-05 subaru impreza Gauge Cluster Speedometer ? will it fit and work fine? mines its a 2002 wrx.
its cheap, everything works and has a few less miles then mine thats all... will a 04-5 work on my 02?
Please help!
alexxxphilly is offline
post #2 of 24 Old 06-09-2009, 09:29 PM
nj kiter's Avatar
nj kiter is an unknown
first problem would be the 87 octane, if i am correct the wrx needs at least 91, but i am not 100 percent sure so double check
second problem is i am pretty sure that you can swap them in but do you research on the swap
nj kiter is offline
post #3 of 24 Old 06-09-2009, 09:37 PM
yeah the CEL is definitely the crappy gas you put in...in our cars you need to run the best available in your area...and as for the gauge cluster yes you can swap them but just search NASIOC or ScoobyMods.com for the instructions on what you need to do
post #4 of 24 Old 06-09-2009, 09:38 PM Thread Starter
now ill just wait till tanks empty n change n see whats up... but the speedo idk... i realy want to know if i can just buy it n get over with.... buy+plug and go.
post #5 of 24 Old 06-09-2009, 09:59 PM
you could just search the forums for an 02-03 cluster and it'll just plug right in
post #6 of 24 Old 06-09-2009, 10:11 PM Thread Starter
true... just the 04-05 look a lil better. but i dont feel like doin all the work and at the end not working lol so ill prly end up doing that get a 02 haha
post #7 of 24 Old 06-09-2009, 11:11 PM
You are crazy for not getting that gas out of the tank. You are doing all this work to your car, I would really hate to see your engine take a dump because you decided to run it till it empties.
I would see if you could maybe put a couple of gallons of 100 octane (if you could find some) and really stay out of boost and refrain from WOT fun.
post #8 of 24 Old 06-10-2009, 09:45 AM
You need to get the DTC read and your problem could be the Vehicle Speed Sensor and not the gauge cluster........
dumdum is offline
post #9 of 24 Old 06-10-2009, 02:41 PM Thread Starter
I know... so all you guys only use 89 or 91? never ever 87?
and the clauster oh well i just get a new one not biggie..
post #10 of 24 Old 06-10-2009, 03:05 PM
Kyole's Avatar
Kyole is an unknown
with the gas issue, instead of searching for 100 octane and running more of the crappy 87 through your engine, you could buy some octane booster additive and see if it helps...not too sure if it would or not. just my two cents
Kyole is offline
post #11 of 24 Old 06-10-2009, 03:08 PM
If 93 octane is in your area do not use anything less than that. If not, don't use less than 91.
post #12 of 24 Old 06-10-2009, 04:17 PM Thread Starter
GOT itttt.... never makin that mistake again
post #13 of 24 Old 06-10-2009, 05:40 PM
03 CrazyTaxi's Avatar
You are going to destroy the motor by putting 87 in. ANY forced induction (turbo/SC/whatever) has to run a higher octane. Minimum on the WRX/STIs is 90, if not you WILL have detonation and be looking for a new motor or a new car. Octane boosters WILL NOT work. Drain the tank, fill it with the good stuff. Next time, do your research before buying a turbo car and you won't have this problem.
As for the CEL, get it read at AutoZone or some other generic parts store and post the code.
03 CrazyTaxi is offline
post #14 of 24 Old 06-10-2009, 08:10 PM
jed344's Avatar
jed344 is an unknown
i have never even ran 87 in any vehical i run 92 ### thats best i can get were i live:P
jed344 is offline
post #15 of 24 Old 06-10-2009, 11:08 PM Thread Starter
BEFORE my subbi i had a 95 talon turbo awd. and used 87 for 2 years... ran like a champ... n still does. thats why i didnt care bout putin 87 on my wrx. with a TURBO""" but got it... the wrx cnt take cheap gas then aint puttin cheap gas. thats all...
