-   -   Oil Cooler O-Ring Help (http://www.wrxtuners.com/forums/f72/oil-cooler-o-ring-help-33302/)
jakewest209 11-23-2012 06:32 PM
2002 wrx, stock everything
Ok, im ready to put in a new cooler o-ring, but I dont have a socket that fits the bolt/screw that is in the middle, anybody know what size I need to go and buy? also is there anything else i might need to know or any useful tips?
psinuse 11-23-2012 08:19 PM
I'm pretty sure it's a deep well 15/16" 6 point if I remember correctly...
jakewest209 11-27-2012 05:55 PM
OK, so i guess the o-ring wasnt the problem, its still leaking oil, dammit! i guess the next culprit is the cooler itself? or is there something else cheap i can try first? im not looking foward to this again, so if there is any info i can get my ears are open
psinuse 11-27-2012 06:58 PM
The last time the oil was changed did you replace the copper o ring on the bolt? Honestly try cleaning everything off the bottom really good, then let the car sit over night with a piece of cardboard under it. That will help you zero in on where the leak is coming from.
jakewest209 11-28-2012 06:03 PM
no i havent changed the copper o-ring, how would that cause it to leak since the bolt is internal within the cooler and the filter? and the only time it seems to leak is when i drive the car around, at idle or when the engine is off it doesnt leak at all. Im guessing it's the increase of pressure as the car is being driven??? This all started after a simple oil/filter change too, which seems so odd to me.
psinuse 11-28-2012 06:22 PM
No the copper o ring around the bolt on the oil pan...I bet that's where it's coming from.
jakewest209 11-28-2012 06:32 PM
dont think so, the oil is coming straight down onto the filter itself, the drain bolt isnt leaking at all, already checked that
good thought though
psinuse 11-28-2012 10:52 PM
Hmmmmm well poop. It's late, but tomorrow I will look on the motor I am building and see if I might have any other ideas...
pzr2874 11-29-2012 05:43 AM
And you checked the lines above the filter?
Degrease everything underneath and start it when under the car.
jakewest209 12-02-2012 12:32 AM
did you ever get a chance to look at your motor? ts been raining pretty much nonstop here, so i havent had a chance to get anything done on my part. i need a garage, haha
psinuse 12-02-2012 06:49 AM
I know this my sound like a bad idea, but undo your oil filter and see if you have it on right...make sure to wipe oil on the rubber seal ring at the top...
jakewest209 12-08-2012 12:31 AM
well. i resorted to taking the car into a mechanic i trust, but still i hate doing so... he looked it over, and only found that it seems to be leaking only from the filter.... this is the 3rd filter that has been put on (since the leak) and i have changed many a filter in my day and never had a problem like this. so my thoughts are maybe i need to get an actual "subaru" filter as a last (cheap) try? my only other thought is maybe there is a small crack or something in the cooler itself at the bottom???
pzr2874 12-10-2012 05:55 AM
Suby filters are your best bet for oil changes anyways.
jakewest209 12-11-2012 10:58 PM
but do you think a non-suby filter could cause an oil leaking problem??? the mechanic i took it too even put another filter on... still leaking...
pzr2874 12-12-2012 05:50 AM
Unless someone put on the incorrect filter (previous owner) I wouldn't think so.
What did the mechanic say?
