O.K.......what is this noise?? - Subaru WRX Forum
post #1 of 11 Old 01-19-2006, 07:37 PM Thread Starter
rexin's Avatar
rexin is an unknown
I recently just put on my TBE, now when I`m at a dead stop & rev the engine a lil it makes a weird noise SOMETIMES. & it`s not spool or just the usual sound of more air flow, kinda sounds like somethin is loose shakin inside of somewhere?? it is a low faint noise but was never there before, noticed it after I put the Dp on?? still runs strong & everything is normal?? Any & all recomendatios would be appreciated
rexin is offline
post #2 of 11 Old 01-19-2006, 08:23 PM
bradley03's Avatar
bradley03 is an unknown
Did you check for exhaust leaks? That might be a possibility.
bradley03 is offline
post #3 of 11 Old 01-20-2006, 08:49 AM
nick4592's Avatar
Valve Chatter maybe..did you drop a nut or bolt into the downpipe?
nick4592 is offline
post #4 of 11 Old 01-20-2006, 10:45 AM
genkidama20's Avatar
genkidama20 is more helpful than not
Send a message via AIM to genkidama20
Probably just a rattle. The DP must be hitting something. Look under there again and make sure it's clear of other parts. If not, unbolt, and re-position.
Xam - 2004 WRX - Cobb Stg II - Ugly Ricer Spoiler
genkidama20 is offline
post #5 of 11 Old 01-20-2006, 11:05 AM
9d2TSi's Avatar
I have that noise in my car as well. I just take it as noise that was always there, just getting muffled by the cats and heat shield. Just check your system over again, making sure that nothing's loose or leaking.
9d2TSi is offline
post #6 of 11 Old 01-20-2006, 11:50 AM Thread Starter
rexin's Avatar
rexin is an unknown
thx fer tha replys guys!! I have seen a tad lil bit of oil leak out of the top of the dp where it connects to the turbo, just a lil though!!! you guys seen this??
rexin is offline
post #7 of 11 Old 01-20-2006, 12:00 PM
nick4592's Avatar
Well partner you got blow by and an exhaust leak..
nick4592 is offline
post #8 of 11 Old 01-20-2006, 02:10 PM
9d2TSi's Avatar
You might want to have someone look at it. It's now soundng like you've got a few things that could be wrong, it's time that you bite the bullet and have it checked out. We can throw guesses at you all day, but until you have it looked at you won't know for sure.
9d2TSi is offline
post #9 of 11 Old 01-20-2006, 02:24 PM
GetUpInDer's Avatar
GetUpInDer is an unknown
There is a small oil line that goes into the bottom of the turbo. When you put on your DP you may have loosened the connection if you manhandled your turbo around to much. Grab a mirror and a flashlight to see where its comming from. Remember that oil doesnt usualy leak up so find the highest point of the leak and start in that area.
GetUpInDer is offline
post #10 of 11 Old 01-20-2006, 03:50 PM
nick4592's Avatar
Very True
nick4592 is offline
post #11 of 11 Old 02-26-2006, 08:11 AM
gingertooth is an unknown
if it is oil leaking, would that still mean that the noise he is getting is related to it? cause i am getting a squeeling noise when i accelerate in 2nd and 3rd when the car is not completely warm. when the car is hot i never get it. weird. but it sounds like it is coming from the turbo side of the engine compartment.
gingertooth is offline
