noise in front left wheel area - Subaru WRX Forum
post #1 of 13 Old 01-24-2009, 06:11 PM Thread Starter
norcalwrx916's Avatar
norcalwrx916 is on thin ice
Send a message via AIM to norcalwrx916 Send a message via Yahoo to norcalwrx916
Sorry if topic wasnt writen right
i have a 03 wrx wagon i have been noticeing a noise coming from my front left side wheel.
sounds like there is a branch stuck on there or tie-rod moving around i checked to see if ther was something stuck wedged in there nothing to be found but i did not check the tie-rod. This sound is only made when moving really slow 1-10mph then goes away when speeding up nothing heard again till i stop and go.
has anyone had this same problem or anything like it...
norcalwrx916 is offline
post #2 of 13 Old 01-24-2009, 06:54 PM
sleepr's Avatar
Images: 13
check for loose lug nuts...I had two lug nuts (next to each other) that were loose on a front wheel and the sound it made while driving at low speeds sounded like the strut was shifting in its perch (but was actually the wheel slightly shifting on the hub).
...If it's not lug nuts, then it would also help if you could identify the noise specifically, like a screech, a clunk, a tap, whine, howl, crunch, etc. Does the noise repeat with the same frequency as the wheel turning, or only once whenever the car's weight shifts from side-to-side or front-to-back or back-to-front?
Matt
Stroked and stoked!
sleepr is offline
post #3 of 13 Old 01-24-2009, 09:26 PM Thread Starter
Ok so I just went for a drive and thought I would listen to see where the noise is coming from well its not the front left wheel its the rear left and sounds like something is draging on the ground or clunking back there...the noise goes away once you get going faster.....
post #4 of 13 Old 01-25-2009, 01:42 AM
do u have aftermarket exhaust?
check to see if your exhaust hangers are in good condition and look for evidence of rubbing on your exhaust
post #5 of 13 Old 01-25-2009, 04:29 PM Thread Starter
yes i have aftermarket exhaust.
i will go check my hangers and look for that type of stuff and get back
post #6 of 13 Old 01-25-2009, 07:42 PM
BLUESHIRT is an unknown
it happened to me before too,but it was my rear left or right rotor that was dirty so i had it cleaned out.another time the noise came from the engine when i thought it was coming from the rotor,part of the engine was touching the heat shield so the shop had to bent the heat shield to stop the rattling noise.
BLUESHIRT is offline
post #7 of 13 Old 01-25-2009, 11:13 PM Thread Starter
alright i will check that too thanks
post #8 of 13 Old 01-26-2009, 01:23 PM Thread Starter
ok so i check my hangers and they are all good and exhaust is good also no rubbing or sign...anything else it could be
post #9 of 13 Old 01-31-2009, 09:09 PM Thread Starter
ok news update everyone...so today i put he car in the air and the noise seems to be coming from the rear diff and makes that clunking sound is this normal or did i hit it right on the head and needs new oil what could it be and how do i check the fluidin the rear or could someting need to be greased?????
post #10 of 13 Old 01-31-2009, 11:18 PM
03 CrazyTaxi's Avatar
If it's coming from the rear diff, you may have some issues. Can't say I know what could be going on. The sound isn't coming only on a hard shift, right? If that's the case, it's pretty much normal in those circumstances. Aside from that, I dunno.
03 CrazyTaxi is offline
post #11 of 13 Old 02-01-2009, 08:48 PM Thread Starter
when i had the car in the air or started turning the rear left wheel and it sounded like the same sound it would as if i were rolling....it doesnt happend during any shift it only makes the sound in 1st gear going 1-10mph and once passed that its totally goin soo i have no clue...im really temped to take it to the shop and find out but dont wanna pay some obnoxious price...
post #12 of 13 Old 02-02-2009, 10:33 AM
i think that first gear clunking noise you are talking about is the sound of when you let the clutch out and makes that sound when your gears are under load. i know when i had my 03 wrx had the same thing. they all do that if that's what im thinking of.
i dont think it's a problem. first gear on the wrx is a little rough compared to most cars. just takes a little getting used to and try letting out of the clutch a little slower, it wont happen as bad.
post #13 of 13 Old 02-02-2009, 04:34 PM
04wrxhart is an unknown
omg good i hear that noise in my 04 every now and then and once i hear it, its hard to make the sound repeat but it does happen in first when im pulling from a stop and it use to scare the hell out of me, but i guess i can breathe now when im pulling out of first lol. thanks.
04wrxhart is offline
