No power..WTF! - Subaru WRX Forum
post #1 of 7 Old 04-02-2011, 07:40 PM Thread Starter
doctorjf21's Avatar
doctorjf21 is an unknown
No power..WTF!
Please help me out! While replacing a headlight bulb, I noticed some massive corrosion on the positive terminal of the battery. I removed and replaced the positive lead and now have NO power to the entire car...no lights, alarm, dash, etc. The battery is putting out 12.5v and the ground is solid. I tried jumping the car and nothing, not even a dim from the lights or dash. I also tried resetting the ECU, but nothing. Anybody have suggestions??
doctorjf21 is offline
post #2 of 7 Old 04-02-2011, 08:02 PM
you replaced the main positive lead? or just the terminal?
post #3 of 7 Old 04-02-2011, 08:07 PM
replaced your lead?
once again disconnect, wire brush and reconnect and see what happens. It almost has to be your connection. I dont see how the problem could be any further than where you were working. And if you only fooled with the headlights than the battery connection almost has to be where your problem lies.
post #4 of 7 Old 04-02-2011, 09:32 PM Thread Starter
doctorjf21's Avatar
Just the terminal. Wire brushed everything and rechecked ALL fuses...still nothing. Could it possible be an alarm issue, maybe a lock out or something?
post #5 of 7 Old 04-03-2011, 01:04 PM
wagonracer's Avatar
Yep, I would suspect your alarm. On the older subies, if you disconnect the battery it puts the alarm in "stupid mode". You have to reset it to get power back, however I've never experienced that on any of the many WRX's I've worked on.
Two ways of resetting: reconnect the battery with key on, or find the reset button under the dash, hold it for three seconds with key on. It's about two inches long and connected to two brown wires.
With all that said, I'm not so sure that's the problem because when the alarm needs to be reset, either your parking lights or the alarm indicator on the dash flashes. You didn't mention anything flashing. Hmmmm.....
wagonracer is offline
post #6 of 7 Old 04-03-2011, 01:17 PM
Wagon, also when the alarm is in stupid mode doesn't the interior light work?
post #7 of 7 Old 04-03-2011, 01:29 PM
wagonracer's Avatar
I don't remember. I guess I've always helped people with that during the day It's also usually people who don't have their fob anymore. I think you can reset it with that too, but I've never had it happen at all on a WRX.
Just taking a wild swing at the OP's problem
