No injector pulse or spark?? - Subaru WRX Forum
post #1 of 18 Old 10-11-2013, 09:00 PM Thread Starter
STravis is an unknown
I have an 04 wrx that I bought as a project. All the injectors have power but only the injector on cylinder 1 has a pulse. None of the other injectors have a pulse. Where are the grounds for the injectors? What else could the problem be?
STravis is offline
post #2 of 18 Old 10-11-2013, 09:48 PM
have you pulled each one and tested them? might be clogged
post #3 of 18 Old 10-11-2013, 11:42 PM Thread Starter
I have pulled the plugs off of the injectors and every plug has 12 volts but no ground to produce the pulse. The only injector plug that gets a pulse is on cylinder 1.
STravis is offline
post #4 of 18 Old 10-13-2013, 04:08 PM Thread Starter
bump..
STravis is offline
post #5 of 18 Old 10-14-2013, 06:40 AM
Ok, what made you pull the injectors? Because not running? Because cleaning?
edit: found other thread
Electical and vacuum help please.
post #6 of 18 Old 10-17-2013, 07:06 PM Thread Starter
Update: the plugs actually do have spark, just no injector pulse.
STravis is offline
post #7 of 18 Old 10-17-2013, 09:42 PM Thread Starter
Bump...any ideas on what to check for injector pulse??
STravis is offline
post #8 of 18 Old 10-17-2013, 10:05 PM
Try another set? Or just one. Have you tried cleaning them yet?
post #9 of 18 Old 10-17-2013, 10:07 PM Thread Starter
There is no pulse to the plug. I have a test light and it isn't flashing when the engine is cranking.
STravis is offline
post #10 of 18 Old 10-20-2013, 01:29 PM Thread Starter
ttt..
STravis is offline
post #11 of 18 Old 10-23-2013, 02:04 PM Thread Starter
If I found a replacement ecu out of the same year, transmission, and the ecu had the same part # would I need to take it to a Subaru dealership to have it programmed or should I be able to just swap it in and try it?
STravis is offline
post #12 of 18 Old 10-23-2013, 02:41 PM
Haw1es's Avatar
Haw1es is more helpful than not
If all the parts are the same,ie it came from a stock ej207 and you have a stock ej207 I think all you would need is to swap the 2 units.
Shane
2010 WRX
2014 F150
Haw1es is offline
post #13 of 18 Old 10-23-2013, 04:49 PM
Why would the ECU fix it?
post #14 of 18 Old 10-23-2013, 09:37 PM
Did you check the fuse for the injectors?
post #15 of 18 Old 10-23-2013, 09:49 PM
Recent engine bay pic please
