-   -   No injector pulse or spark?? (http://www.wrxtuners.com/forums/f72/no-injector-pulse-spark-40194/)
STravis 10-11-2013 08:00 PM
I have an 04 wrx that I bought as a project. All the injectors have power but only the injector on cylinder 1 has a pulse. None of the other injectors have a pulse. Where are the grounds for the injectors? What else could the problem be?
pzr2874 10-11-2013 08:48 PM
have you pulled each one and tested them? might be clogged
STravis 10-11-2013 10:42 PM
[quote=pzr2874;372978]have you pulled each one and tested them? might be clogged[/quote]
I have pulled the plugs off of the injectors and every plug has 12 volts but no ground to produce the pulse. The only injector plug that gets a pulse is on cylinder 1.
STravis 10-13-2013 03:08 PM
bump..
pzr2874 10-14-2013 05:40 AM
Ok, what made you pull the injectors? Because not running? Because cleaning?
edit: found other thread
[url]http://www.wrxtuners.com/forums/f72/electical-vacuum-help-please-39969/[/url]
STravis 10-17-2013 06:06 PM
Update: the plugs actually do have spark, just no injector pulse.
STravis 10-17-2013 08:42 PM
Bump...any ideas on what to check for injector pulse??
pzr2874 10-17-2013 09:05 PM
Try another set? Or just one. Have you tried cleaning them yet?
STravis 10-17-2013 09:07 PM
There is no pulse to the plug. I have a test light and it isn't flashing when the engine is cranking.
STravis 10-20-2013 12:29 PM
ttt..
STravis 10-23-2013 01:04 PM
If I found a replacement ecu out of the same year, transmission, and the ecu had the same part # would I need to take it to a Subaru dealership to have it programmed or should I be able to just swap it in and try it?
Haw1es 10-23-2013 01:41 PM
If all the parts are the same,ie it came from a stock ej207 and you have a stock ej207 I think all you would need is to swap the 2 units.
turmic 10-23-2013 03:49 PM
Why would the ECU fix it? WTF
psinuse 10-23-2013 08:37 PM
Did you check the fuse for the injectors?
BLAZE2099 10-23-2013 08:49 PM
Recent engine bay pic please
