No cooling fan - Subaru WRX Forum
post #1 of 4 Old 12-13-2010, 10:16 PM Thread Starter
No cooling fan
Hello, I have an 05 WRX and what temp is the cooling fan on the radiator suppose to come on. Mine seems to be taking an early vacation. I unplugged the fan and hit it with a wire off the battery and it spun just fine, is there a sensor that has gone bad ? Thanks
FranzKlammer is offline
post #2 of 4 Old 12-13-2010, 10:33 PM
wagonracer's Avatar
Did you check fuses ?
wagonracer is offline
post #3 of 4 Old 12-14-2010, 08:07 PM Thread Starter
It's not the fuse-
post #4 of 4 Old 12-14-2010, 08:41 PM
wagonracer's Avatar
Put the car in the diagnostics loop by plugging together the two green plugs under your dash. That will cycle all your relays sensors and solenoids, and both fans should cycle on and off.
I would check the relay next (you should hear it click), while in the loop.
If that doesn't get you anywhere, check the sensor which is a bitch to get at. It's under the intake plenum on the cast coolant pipe that goes across the top of the block.
Don't forget to unplug those when you're done. Hope that helps
