-   -   no CAT CEL (http://www.wrxtuners.com/forums/f72/no-cat-cel-2296/)
deezwrx 06-17-2003 03:53 PM
no CAT CEL
i was driving for 20 min when i was merging onto a major highway, so i merged hella fast on. i was doing 80 mph when my check engine light poped up! i was like what the hell!?? so i took it to my friend who is a micanic, and owns a wrx. he ran a scan and the computer told him that there was a malfunction on the up pipe CAT, wich we had removed with the gruppie pipe. he cleared the CEL, and it is fine now.
will this happen again, and how can i make it so it doesnt happen again!?
will the computer learn that there is no CAT!??
Cosmo 06-17-2003 05:16 PM
Yes, it will happen again. You need a MIL eliminator from [url]www.ponyexpressperformance.com[/url] or you can make your own: [url]www.dooleyprinting.com/brsc/O2_Mil_Fix.doc[/url]
[b][url=http://autoinsurances.wearecares.net]Best Auto Insurance[/url] | [url=autoprotection.wearecares.net]Auto Protection Today[/url] | [url=trade-in.wearecares.net]FREE Trade-In Quote[/url][/b]
deezwrx 06-18-2003 03:58 AM
MIL Eliminator (one for single rear O2 sensor). would this work for my up-pipe, is it concitered a rear 02 sensor?????
thanks DEEZ
Kobiyashi 06-18-2003 09:26 AM
there should be no Code for the cat in your uppipe. The front O2 sensor must be intact to operate the car. DO NOT MIL ELIM. IT!!!
-Kobi
fc735 06-18-2003 09:45 AM
what code number? need to know that to tell what the problem is...the uppipe cat has no effect on the downstream reading....the downpipe cat will....lemme know what it is.
JOEY
deezwrx 06-20-2003 04:15 AM
sorry guys i am a big dumb a$$ it wasnt the up-pipe, it was the down pipe. well, ill look into the elm elimonator
DEEZ
fc735 06-20-2003 12:00 PM
you can save yourslef some money if you are elecrically competent. it involves soldering a 2.2k ohm resistor in series to the downstream o2 signal wire to the ecm. i think it was the white wire, but dont hold me to that. someone please correct me if i am wrong. the pinout at the ecm is terminal 17, on connector b135......the 20 pin connector. sorry...my scanner is down..otherwise i would scan my printout from alldata.....im sure someone has the link. cosmo does, i think.....
hope this helps
JOEY
