No 1st gear!? - Subaru WRX Forum
post #1 of 10 Old 12-28-2010, 06:45 PM Thread Starter
silvr_wag's Avatar
silvr_wag is an unknown
No 1st gear!?
I live about an hour North of Philly. We got some snow on Sunday. I got stuck in said snow yesterday. I have an 02 WRX wagon and it usually can get out jams like this. I was trying to get out for a good ten minutes. I finally got out and came up to a red light to find that I now cannot get into first gear. Does this sound like a synchros problem or a bigger transmission problem?? Any help is appreciated. Thanks.
silvr_wag is offline
post #2 of 10 Old 12-28-2010, 07:04 PM
anxiouz's Avatar
anxiouz is an unknown
Sounds like a syncho problem to me. Maybe your tranny fluid isn't robust enough for the weather?
Steve ... '11 WRX H/B ... Perrin Stage 2
anxiouz is offline
post #3 of 10 Old 12-29-2010, 07:54 AM
It's possible. When was the last time you changed your transmission fluid? It should be done every 30k or so. If you're using cheap/stock fluid or don't know what's in there, give the Andrewtech Cocktail a try:
(1x) 1 Liter Motul Gear 300 75W-90
(3x) 1 Quart Redline Lightweight Shockproof Gear Oil 75W-140
Might be worth a shot spending 50 bucks or so to see if you can fix the problem yourself before you take it to the dealer and spend several hundred or thousand.
post #4 of 10 Old 12-29-2010, 09:52 AM Thread Starter
silvr_wag's Avatar
I've got Redline fluid in there. I probably put it in 20k mi. ago. Guess I'm going to have her get checked out. Thanks.
post #5 of 10 Old 12-29-2010, 12:37 PM
Darn, that's probably not it then. I used Redline 75W-90 NS in my transmission immediately after initial break-in from 3,000-60,000 miles with no ill effects. I switched from that to the Andrewtech Cocktail at 60,000 and I currently have ~72,000 - again, no ill effects.
Something mechanical is probably screwed up. Get ready to spend some mula
post #6 of 10 Old 12-29-2010, 07:51 PM
John, Andrew recommends changing the cocktail every 15-20K
post #7 of 10 Old 12-29-2010, 10:47 PM
Oh really? I didn't know that. Is that just for the fluid in general, or for cars that are driven especially hard? I guess I'll be changing that at 80k then instead of 90k as I was planning. I wonder if any companies out there make a quick drain valve for the transmission fluid plug
post #8 of 10 Old 12-30-2010, 05:40 AM
You have a Fumoto already... call em.... I'd like to know also if they make a tranny plug....
post #9 of 10 Old 12-30-2010, 09:13 AM
You're right, I do
The only problem with putting a quick drain valve on the bottom of the trans is that it would stick straight down underneath the car by an inch or two and be unprotected from debris. That's also one of the lowest points under the car, so it makes sense that Subaru used a flat-style plug that's pretty thick on the sides. The oil drain valve is slightly more protected by the plastic guard under the front end and it's mounted slightly higher and at an angle, so I'm not worried about that one. Now that I have the correct Torx bit (T-70 instead of T-60), I'm not too worried about the trans drain plug (I rounded out my first one using the smaller bit so I had to replace it). If there was an easier solution to finding/accessing the trans fluid filler neck behind/under the TMIC, I'd be all over that. It's a pain to always find a second person to help hold the funnel/hose when I fill it up and then I feel bad for them because they have to stand there for a while in an awkward position bent over the engine because the fluid is so thick and it fills sooo slow.
post #10 of 10 Old 12-30-2010, 09:25 AM
Good points....
