New sound.. Help?? - Subaru WRX Forum
post #1 of 8 Old 12-04-2013, 09:54 AM Thread Starter
MetalCoreDrummer is an unknown
New sound.. Help??
Ok, so it is most noticeable when the car is cold. After I put it into first and drive away, it makes a sound that I could best describe as if you consistently shook rice around inside a plastic container, or the "Sshhh," sound you make when you're trying to get someone to be quiet, but a lot louder. The sound goes away when I press the clutch in, but occasionally comes back in higher gears. The sound usually occurs in first or second though. I'm assuming its a lubrication issue... Any ideas?? It happens a lot less after the car is warmed up.
It's an 02 wrx sedan
MetalCoreDrummer is offline
post #2 of 8 Old 12-04-2013, 10:15 AM
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
where is the sound coming from? can you localize it for us?
another option is trying getting it on video for it.
is the car stock or what modifications do you have on the car?
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #3 of 8 Old 12-04-2013, 10:21 AM Thread Starter
That's just the thing. I couldn't figure out exactly where it was coming from... But the car is bone stock. 67k miles. I'll try to get a vid up this afternoon
post #4 of 8 Old 12-04-2013, 11:43 AM
you hitting boost target on WOT?
post #5 of 8 Old 12-04-2013, 12:35 PM Thread Starter
I believe I am.
post #6 of 8 Old 12-04-2013, 02:03 PM
Have you drained the gearbox and looked for shards or particles ? Does it do it in neutral (cold start) and then go away once the clutch is pressed in ? If so, sounds like a throw-out. I guess I misunderstood at first.
post #7 of 8 Old 12-04-2013, 05:09 PM
boo-key's Avatar
^^this^^
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #8 of 8 Old 12-04-2013, 09:24 PM
Premium Member
the RIOT act's Avatar
I'm def thinking throw out bearing. Esp how it goes away when you press the clutch in. That's usually the tell tale sign.
Sent from AutoGuide.com App
Brandon - 13' SWP WRX Sedan
the RIOT act is offline
