New noise - Subaru WRX Forum
post #1 of 12 Old 03-30-2012, 12:22 AM Thread Starter
wrxcyan44's Avatar
wrxcyan44 is an unknown
New noise
So my right front jut started making a new weird noise that I can't figure out for the life of me. It sounds like a rubbing kinda noise but doesn't do it when I step on the brakes or when I accelerate just when I'm coasting. Speeds up faster I go. Nothing appears to be rubbing visually but no idea what else it could be? It seems when I raise the up it and put it back down it doesn't do it anymore for awhile and then comes back. What the French could it be?!
Sent from my Autoguide iPhone app
wrxcyan44 is offline
post #2 of 12 Old 03-30-2012, 02:02 AM
bad grocerygetter's Avatar
Wheel bearing?? Jack the car up, try and wiggle the wheel if it moves, that's your problem.
Kevin.
bad grocerygetter is offline
post #3 of 12 Old 03-30-2012, 07:59 AM
Are your tires chopped up?
http://i56.photobucket.com/albums/g1.../BMW/tires.jpg
post #4 of 12 Old 03-30-2012, 08:49 AM
I vote bearing
post #5 of 12 Old 03-30-2012, 01:46 PM Thread Starter
wrxcyan44's Avatar
I do need an alignment. I could try that. It only does it at speeds below 30ish and doesn't do it when I turn
post #6 of 12 Old 04-02-2012, 11:44 PM Thread Starter
wrxcyan44's Avatar
Just a follow up, put my new wheels and tires on and problem is gone. Car drives like dream. alignment on Wednesday but feels damn good now.
post #7 of 12 Old 04-03-2012, 12:37 AM
Your struts are dying. You had Racelands right?
post #8 of 12 Old 04-03-2012, 01:07 PM Thread Starter
wrxcyan44's Avatar
No they're fine. Ksports kontrol pros. And it was the tires being chopped.
post #9 of 12 Old 04-03-2012, 03:19 PM
The biggest cause of tires getting chopped is weak struts. If they weren't already that way when you installed the coils, then it will happen to the new tires as well unless you fix whatever was causing it.
post #10 of 12 Old 04-03-2012, 05:08 PM Thread Starter
wrxcyan44's Avatar
Alignment caused it.
post #11 of 12 Old 04-04-2012, 07:12 AM
^He did call chopped tires from the begining
Just sayin
post #12 of 12 Old 04-05-2012, 03:45 AM Thread Starter
wrxcyan44's Avatar
Didn't say he didnt
