Old 01-11-2008, 12:44 AM   #1 (permalink)
atxwrx's Avatar
Club Region: Gulf Coast
Reputation: atxwrx is an unknown
Need some serious help...
I was driving home from work and as I was turning a corner in 3rd, my car lost boost, started sputtering/shuttering, etc and threw a CEL. The first thing I thought was that I had some type of exhaust leak since that has happened before. I checked all gaskets (even put in some seafoam to see if smoke would come out of any area it wasn't supposed to) but I did not find anything. I tried resetting the ECU and loading back my map. I turned the car on and the CEL was gone. I took it out for a test drive and as soon as I got to around 3500rpm, same sputtering, loss of boost, CEL. I checked the codes and this is what it gave me...
P0500
P1518
P1591
P0131 - o2 sensor circuit low voltage (bank 1 sensor 1)
P0132 - o2 sensor circuit high voltage (bank 1 sensor 1)
I searched but I have found nothing... And no, it is not in test mode and the green clips are not together. ANY info would be greatly appreciated.
Old 01-11-2008, 09:43 AM   #2 (permalink)
Post all your engine mods and list anything you have done or installed in the car recently.Did you possibly install a turbo timer recently?P1518 is a starter switch code and P1591 is nuetral saftey switch.P500 is vehicle sensor malfunction.Try reflashing back to stock and see what happens.If it goes away their is a problem with the map(maybe wrong year ecu),if not then it's with the car.
Aarg matey!
ECU Pirated by RomRaider
Old 01-11-2008, 10:04 AM   #3 (permalink)
atxwrx's Avatar
I have only done basic mods...
Megan Uppipe
Titek catted downpipe
Skunk2 exhaust
K&N drop in filter
Ebay TMIC
I checked all gaskets for leaks and bolts to see if anything looked funky and everything is fine. Could a bad o2 sensor be the issue? But that wouldn't explain the other codes.
I reflashed the ECU back to stock but then I put the stage2 map back in...
Old 01-11-2008, 01:07 PM   #4 (permalink)
What map are you using and are you sure it's the right map?Sounds like maybe your using a map for a car with a different transmisson.It might be time for you to get an new O2 sensor.They generally are replaced every 60-75K miles.
Aarg matey!
Old 01-11-2008, 01:38 PM   #5 (permalink)
atxwrx's Avatar
I am going to try that... I know it is a little expensive, but the one I have looks fairly old and my car is almost at 90k miles. I have also just replaced the brake lines so that may have something to do with the speed sensors, even though I was careful not to tug at any wires.
Old 01-11-2008, 03:24 PM   #6 (permalink)
The vehicle speed sensor is in the trasmisson.
Aarg matey!
Old 01-12-2008, 01:04 PM   #7 (permalink)
atxwrx's Avatar
I feel really stupid... It looks like the problem was the result of something that I did when I did my exhaust mods. I went to the dealership to get a new o2 sensor, gaskets and picked up a new battery also. When I went to remove the air intake box so I could remove the o2 sensor wire easier, I realized that the lower coil pack on the passenger side was hanging out. Then it dawned on me what happened. When I had replaced my uppipe and downpipe a few months ago, I had to remove the o2 sensor. When I went to reconnect it, I didn't use the correct bolt that holds the o2 sensor wire bracket, which is also the bolt that goes into the coil pack. I got the correct bolt, put the coil pack back in, reflashed the ECU and everything is as good as new. The positive thing is that since I had to have the car on the ramps, I took time to replace my end links, pitch stop mount, and light weight pulley that I have been meaning to install. dumdum, thank you for all of your input. I really appreciate it.
Old 01-13-2008, 11:27 AM   #8 (permalink)
Anytime!Glad you figured it out!
Aarg matey!
