Need HElp! Check engine code P0545 - Subaru WRX Forum
post #1 of 10 Old 03-04-2004, 12:11 AM Thread Starter
sunny is an unknown
Unhappy Need HElp! Check engine code P0545
My car is running with a straight pipe , cold air injen intake, Sqqbv , resistor for the rear O2. My car was running fine. esle for the backfires .. couple weeks after i install my upipe and downpipe.. when i boosted my car pretty hard.. a check engine came on. I scan it.. codes came out
P0102a MAF?VAF ciruit low input, P1301 Mfr ctrlled Ign or Misfire,
P0113 IAT ciruit High Input, P0545 Exhaust gas Temp sensor Ckt low,
P1544 Mfr Ctrl Veh spd, Idle Ctrl, Aux Inp
So i clear the codes, and cleaned the MAF. engine was off, later that day i boosted again.. CHECK ENGINE CAME BACK ON. this time
P0545 exhaust gas Temp sensor Ckt low. was the first code.
what could be the problem with this code.. my car has about 63,000 miles 2002 wrx .. i think i might need a new gas temp sensor.. or clean it some how.. or maybe some other problem that cause it?? or do i need a resistor for the gas temp or something?? i dunno
sunny is offline
post #2 of 10 Old 03-04-2004, 12:47 AM
AZ-Scoob's Avatar
AZ-Scoob is an unknown
Send a message via MSN to AZ-Scoob
do you have the resistor in the EGT circuit? it is the sensor in the up-pipe that reads exhaust gas temp. if it isnt resistored it will throw a code. cannot recall the code right now, however it is related to the sensor in the up-pipe not reading the cat that was there. could be the airflow through the up-pipe is fast enough from prior ECU settings that it is throwing as code for too cool a temp in the exhaust at high rpm, high boost situations
[I]"Winners never quit, quitters never win, those that never win or quit are idiots."[/I]
AZ-Scoob is offline
post #3 of 10 Old 03-05-2004, 11:29 PM Thread Starter
sunny is an unknown
EGT problem...
No resistor in EGT. . i am surpose to put a resistor in EGT after replacing the cat-ed up-pipe?? .. if so where can i get one of this resistor..
sunny is offline
post #4 of 10 Old 03-06-2004, 10:29 AM
Kobiyashi's Avatar
Kobiyashi is more helpful than not
Radio Shack
2.2k ohms 1/2 watt resist ... don't have the part # but they come in 5 packs. Just put one in the EGT probe wiring harness, loop it.
-kobi
Kobiyashi is offline
post #5 of 10 Old 03-06-2004, 10:12 PM
AZ-Scoob's Avatar
Bingo! what he said.
AZ-Scoob is offline
post #6 of 10 Old 03-07-2004, 02:48 PM
fc735's Avatar
is it bad i have three of them in my laptop case?
pn 271-1325 at radio shack....1.05 for me.
fc735 is offline
post #7 of 10 Old 03-07-2004, 03:12 PM
Kobiyashi's Avatar
I guess not, down to 2 in mine though =/ but do you have spare m12's to go along with it?
=P
-kobi
post #8 of 10 Old 03-07-2004, 03:15 PM
fc735's Avatar
fc735 is offline
post #9 of 10 Old 03-07-2004, 03:48 PM
Kobiyashi's Avatar
If they are running an uppipe with an EGT probe, a m12x1.25 25mm fits the bung. Most of them I do still have an aftermarket UP with the probe in. You need those to remove it.
-kobi
post #10 of 10 Old 03-13-2004, 10:02 PM Thread Starter
sunny is an unknown
LOL! i already replaced a new EGT sensor.. my car been working fine.. but i just i give it a try.. and i won't have to replace another 50 dollar EGT sensor .. thanks for the help guys!
sunny is offline
