Need Help - Subaru WRX Forum
post #1 of 2 Old 05-30-2010, 10:55 AM Thread Starter
jhwrx05 is an unknown
Need Help
I have an 05 wrx with no mods, its my daily driver. I changed the oil last week, last year my head gasket had a leak so lots of money later the car has been running fine. However yesterday I stopped the car and it was smoking from under the hood, smelled like coolant. When the car was cool i checked the top coolant resevoir on top of turbo, and it was full. My temp gauged had not moved, I checked the oil it was low, brought it back up to level. coolant levels are ok; when the car cools, the overflow is a little above the full the mark. There are no signs of a leak of coolant or oil near where i park. The smoke seams to be coming from below the turbo, maybe near downpipe. I need some suggestions on what to do, and what to keep an eye on, or where to start.
jhwrx05 is offline
post #2 of 2 Old 05-30-2010, 12:09 PM
I would bet you have a bit too much coolant in there and it's draining from the overflow tank. There should be a hose dumping right next to the downpipe that comes from the overflow tank if I'm not mistaken. If that is dumping a bit of coolant and it hits the DP it'll smoke.
If you need a picture I can get you one but just look for the hose dumping behind the pass front wheel area.
