Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 07-05-2009, 09:13 PM   #1 (permalink)
norcalwrx916's Avatar
Club Region: NorCal
Reputation: norcalwrx916 is on thin ice
Send a message via AIM to norcalwrx916 Send a message via Yahoo to norcalwrx916
is my turbo about too!!!
well i just recently put on my up and about later my turbo or something makes a not so good noise when i hit woooot sounds like a whistle being blowin or something close...and yes i know i will hear my turbo when i put the up on but no its not that...car has 112K could my turbo be getting ready to take a shit on me....friend said it could be a boost leak but i dont know
Old 07-05-2009, 09:22 PM   #2 (permalink)
Have you checked for boost leakes yet?
Old 07-05-2009, 09:31 PM   #3 (permalink)
Club Region: NorCal
no i have not cause i dont know how...how do i check for boost leak and if it was would it make that kind of noise
Old 07-05-2009, 09:32 PM   #4 (permalink)
Reputation: srninjastar is more helpful than not
this is gona sound weird but does it make a "ttssssssssss" sound or a "sssshhhhhttt" sound? lol/ if its the 1st one than thats ## turbo, but if its the second you have an exhaust leak. my wrx makes the 2nd sound and i found out cause im missing the dp gasket. did you replace the gasket when u did the install??
Online
Old 07-05-2009, 09:37 PM   #5 (permalink)
Club Region: NorCal
ok i already know i have a small exhaust leak at my cbe but it was making this noise im hearing till the up went on and no i didnt not replace the gasket for the dp and wont i have heard the noise right then??
Old 07-05-2009, 11:48 PM   #6 (permalink)
Timeslip: 9.999 @ 101.26
You should of replaced both your UP and DP gaskets with the OEM-style gaskets.
Willing to bet it's a pre turbo leak.
Old 07-07-2009, 12:59 AM   #7 (permalink)
Club Region: NorCal
the up has new gaskets put not the dp
Old 07-07-2009, 02:41 PM   #8 (permalink)
have you checked for leaks?
One easy way to tell if your UP or DP are leaking at the mating flanges is to see if you have any black exhaust carbon coming out at the flanges where the gasket is at.
Or pressureize the system.
Old 07-08-2009, 12:40 AM   #9 (permalink)
Club Region: NorCal
how do i check for the pressure
Old 07-08-2009, 10:17 PM   #10 (permalink)
03 CrazyTaxi's Avatar
Reputation: 03 CrazyTaxi is known to be trustworthy and helpful 03 CrazyTaxi is known to be trustworthy and helpful
Sounds like a warped exhaust flange
Old 07-08-2009, 11:09 PM   #11 (permalink)
Club Region: NorCal
when the noise comes on it sounds like a dentist trill
Old 07-09-2009, 01:29 AM   #12 (permalink)
Did you already check visually to see if you have any black carbon coming out of the mating flanges?
Old 07-09-2009, 07:44 PM   #13 (permalink)
Reputation: silv03wrxwag is an unknown
I had the same sound on my '03 wrx wagon anddd I got the news that my turbo was dead. Does the sound happen when you hit the gas, gets louder the higher the RPMs go and goes away when you let off the accelerator? if so, it's the turbo. I thought it was an UP leak but unfortunately it wasn't . good luck to you though.
Old 07-09-2009, 08:49 PM   #14 (permalink)
Club Region: NorCal
yes that is what happens but did yours still build boost cause mine does
