My running lights wont shut off - Subaru WRX Forum
post #1 of 8 Old 07-02-2010, 12:05 PM Thread Starter
Jruh22 is an unknown
I have an 02 wrx. I went to install my aftermarket cd deck in so I could hook my sub-woofer up. I hooked everything up. I cut the power wires to hook them to a new block on the postitive side of the battery so everything would be clean. After i hooked everything back up now my running lights wont shut off. I do have hid lights on it with diffrent headlights. Thank-you James
Jruh22 is offline
post #2 of 8 Old 07-02-2010, 04:35 PM
Did you bypass the switching portion of your headlight? Your post is a little confusing. Did you previously disable your day time running lights and now after redoing the battery wires it's enabled again?
What all did you end up cutting off?
post #3 of 8 Old 07-03-2010, 11:32 AM Thread Starter
Sorry if it was confusing. The only thing i cut off was right where it attached to the battery. I changed the end so i could hook a power wire up for my amp.
Jruh22 is offline
post #4 of 8 Old 07-03-2010, 11:34 AM Thread Starter
No, I did not disable the running lights. But now they never shut off even with the key off.
Jruh22 is offline
post #5 of 8 Old 01-16-2012, 11:19 AM
PandaWRX is an unknown
SAme issue
Im having the same problem. the stupid parking lights to include the tag lights won't go off. I haven't touched anything. It just happened
PandaWRX is offline
post #6 of 8 Old 01-16-2012, 11:51 AM
Did you reach across your steering column for anything? The parking light switch its poorly placed right there and people often times hit/bump that without realizing it and the lights are then on. Check that out, might be the problem.
post #7 of 8 Old 01-16-2012, 12:21 PM
Lol. This one always cracks me up. Ive been there.
post #8 of 8 Old 01-17-2012, 07:40 PM
me too haha,when I saw the title I had the answer immediately.
