Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 08-01-2009, 04:25 PM   #1 (permalink)
boo-key bear's Avatar
Club Region: Southeast
Images: 16
Reputation: boo-key bear is an unknown
motor mount not lining up
02 wrx. replaced motor mounts and now driver side is about 1 1/2 away from lining up with the hole in crossmember. I tried prying between the cross pipe and radiator support with no luck. I even tried removing the pitching rod hoping it might free up some movement. The engine needs to move back. Not my car but its stuck in my garage until its fixed. Please help!!!!
TURBO+AWD=REPLACEMENT 4 DISPLACEMENT
Old 08-01-2009, 04:57 PM   #2 (permalink)
Trader Rating: (3)
Are you sure you don't have them assembled backwards? I know the Cusco mounts that I'm running and the OEM mounts that came off my 02 were directional.. If that is not the case make sure that the mounting plates are correct.. As in you don't have (2) passenger ones..
Old 08-02-2009, 08:38 AM   #3 (permalink)
Images: 16
Yes I am sure they are not backwards. When I took the passenger side off I made sure I installed the new one in the same direction as the old one. I also checked for left and right. What a PITA!!
Old 08-02-2009, 02:11 PM   #4 (permalink)
Trader Rating: (3)
I agree, it was a PITA to install the Cusco as well.
Old 08-02-2009, 09:09 PM   #5 (permalink)
Images: 16
Dang!!! You were right LiL Shoaf! I had one in backwards. I thought I had double checked. Everything went smooth after I realized that. Good call man THANKS!
Old 08-03-2009, 05:57 PM   #6 (permalink)
Trader Rating: (3)
Glad you figured it out. I did the same thing. LOL.
