Missing factory connector / resistor mod - Subaru WRX Forum
post #1 of 10 Old 10-17-2012, 08:27 AM Thread Starter
mgilorma is an unknown
Just got my wrx a few weeks ago and just found this connector on the passenger side with a resistor shoved in it. There are two wires with pins on them that look like they are missing the factory connector that I assume plug into this connector. It looks like the wires are coming off the turbo?
Does anybody have any idea what the part number might be for a new connector? I can only assume that the resistor was put in to stop the car from throwing codes.
mgilorma is offline
post #2 of 10 Old 10-17-2012, 10:58 AM
rex2002's Avatar
that plugs up to the egt sensor. looks like the other owner upgraded some parts and did not use the egt sensor. i to did the same with my setup. was the car tuned. if you take the resistors out you may throw a code and the car is not tuned for it. there made to trick the system. http://carphotos.cardomain.com/ride_...0015_large.jpg that link is a picture of the egt sensor
rex2002 is offline
post #3 of 10 Old 10-17-2012, 11:10 AM Thread Starter
The car looks bone stock, no aftermarket parts except a drop in k&n filter. I am trying to get this car to 100% factory and running well before I start throwing some aftermarket parts at it. I had the car checked out at a dealership before I bought it, they said it was in good shape and didn't throw any codes.
I am thinking about just plugging the pins into the socket temporarily until I can get the right housing. Does it matter which pin goes where?
mgilorma is offline
post #4 of 10 Old 10-17-2012, 11:23 AM
rex2002's Avatar
if your not throwing any codes just leave it alone till you get the right connector. b/c it looks like you may have a universal egt sensor b/c the two probes looking things aren't normal. hopefully someone else will confirm what im saying,b/c ive never messed with universal parts
rex2002 is offline
post #5 of 10 Old 10-17-2012, 03:06 PM
Just leave it until you get some form of EM.
post #6 of 10 Old 10-17-2012, 03:31 PM Thread Starter
EM??
Does anybody have a good resource for finding factory parts like the connector I am missing? I could always go to the dealership but would prefer to buy online if possible.
mgilorma is offline
post #7 of 10 Old 10-17-2012, 05:40 PM
Originally Posted by mgilorma View Post
EM??
Engine Management. That connector is part of the wiring harness and not sold as a separate piece. You'll be fine trust me on that.
post #8 of 10 Old 10-18-2012, 01:55 AM
rex2002's Avatar
if he gets a stock egt probe it should have the right connector to plug up into whats already there
rex2002 is offline
post #9 of 10 Old 10-18-2012, 05:51 AM
True, but why waste the money on a part that isn't worth it.
post #10 of 10 Old 11-18-2012, 08:34 AM
BLUWRXWGN is an unknown
Its a 3.3 ohm resistor for the egt removal mod. I did this because my car egt was burnt off throwing a code. Leave it its not needed
Sent from my GT-P7510 using AutoGuide.Com Free App
BLUWRXWGN is offline
