Misfire and shuttering acceleration - Page 2 - Subaru WRX Forum
post #16 of 32 Old 11-29-2012, 05:06 PM
General-Leo's Avatar
General-Leo is more helpful than not
maybe the coils, or the distributer? I don't know a lot about cars but its possible right?
General-Leo is offline
post #17 of 32 Old 11-30-2012, 03:37 AM
Gaspo is an unknown
there is no distributor. its coil on plug. i disconnected my electronic boost controller and now the car runs and boosts fine (14psi) i'm assuming i just have a bad tune.
Gaspo is offline
post #18 of 32 Old 11-30-2012, 01:57 PM
Hondafan's Avatar
Sounds to me like the car is running crazy lean. Fuel Pressure Regulator? I've only had my old Prelude run like that when it was getting tuned for Nitrous and we were about 10% down on the fuel trim from where we should have been. I toasted the spark plugs and actually melted the electrodes off of them. I'd look at the FPR first, and run fuel injector cleaner for sure, as you're likely mixing up crap out of the bottom of the tank every time you fill up and not getting it far from the entrance to the line. That's my $.02.
-Brad
Hondafan is offline
post #19 of 32 Old 02-12-2013, 01:54 PM
Haw1es's Avatar
Haw1es is more helpful than not
Hey, I, new to the forum I recently bought a 2010 WRX. It has 33xxx miles with no apparent mods. I bought it from a subie dealer in my area that took it in on trade. It ran beautifully for the first 2 weeks, then I had the same exact issue everyone here is describing. It threw 2 codes the dealer attributed to a loose connection. They cleaned the maf and replaced the plugs and said I was fine. As it threw a misfire code ~1000 feet from the dealer when they said they "fixed" it they kept it for 2 days. The final diagnosis was bad gas, a vapor test gave a result of 6psi of the gas. I've cleared the bad gas, ran a few bottles of fuel system cleaner through and having the same issue. Up to about 9 psi of boost its fine, after that the car shudders and dumps boost. If I keep accelerating it will throw a misfire code in cylinder 1.
Sorry for the long post, but I really want to get this fixed, the car was amazing when I first bought it but now I'm thoroughly disappointed with it. Any help would be much appreciated!
Haw1es is offline
post #20 of 32 Old 02-12-2013, 02:08 PM
You still under warranty?
post #21 of 32 Old 02-12-2013, 02:55 PM
Haw1es's Avatar
Yea, I got the extended one through the dealer. They basically said they are only concerned with its "drivability" and since technically the car works they can't find anything wrong with it. The first time I had the issue they drove it less than 3 miles.
Haw1es is offline
post #22 of 32 Old 02-12-2013, 04:16 PM
take it to another dealer.. Or talk to the service mgr.
You have to keep on em.
post #23 of 32 Old 02-12-2013, 04:33 PM
Haw1es's Avatar
That sounds like the best option. This is a stupid question and I'm 99% sure I know the answer, but the car should not work like this at all, right? I've been told a few times that it will shudder at WOT and that's normal, but it never did when I first got it.
Shane
2010 WRX
2014 F150
Haw1es is offline
post #24 of 32 Old 02-12-2013, 05:04 PM
If everything is perfect, it shouldn't shudder/stutter/jerk. any mods yet?
post #25 of 32 Old 02-12-2013, 05:16 PM
Haw1es's Avatar
No performance ones that I'm fully aware of, I know the car had a Perrin CAI that was removed, the turbo heat shield is all kinds of jacked up as if someone did a horrible job trimming it for a downpipe/bigger turbo. It does have a Perrin front strut brace, boost gauge and HID lights. It came with a factory installed short shift kit.
Shane
2010 WRX
2014 F150
Haw1es is offline
post #26 of 32 Old 02-12-2013, 05:22 PM
Taking this to your thread
New to Subarus and this forum
post #27 of 32 Old 02-12-2013, 08:55 PM
Cheney is an unknown
When i had my 02' it did that and it was a broken spring in my forge bov. However sounds like your stock wierd. Clean out your air filter or try replacing it won't hurt probably isn't gonna help. Sounds like a vacuum leak somewhere
Cheney is offline
post #28 of 32 Old 03-13-2013, 12:45 PM
Haw1es's Avatar
So wanted to give an update on this and see if anyone has any more ideas. So the car is currently at the dealer and they still have no idea what's causing the issues. They determined that at 8psi cylinder 1 misfires but doesn't store the code. A vacuum/boost leak has been ruled out. A cylinder compression test was done with no issues. The coil packs were swapped around and it still misfires in cylinder 1. A fuel system cleaner was done b/c they found a buildup of carbon in the engine. This also did not resolve it. The dealer is stumped at this point and has reached out to their regional support. Any other suggestions out there? Thanks for the help!
Shane
2010 WRX
2014 F150
Haw1es is offline
post #29 of 32 Old 03-13-2013, 02:29 PM
There might be a new block in your future if they can't find the issue.
post #30 of 32 Old 03-14-2013, 03:20 PM
Haw1es's Avatar
Just a quick update, dealer found it was a dirty fuel injector. They cleaned it and seemed to fix the issue.
Shane
2010 WRX
2014 F150
Haw1es is offline
