Misfire/ boost issue please help - Page 2 - Subaru WRX Forum
post #16 of 23 Old 07-26-2009, 01:08 PM Thread Starter
squirells 06's Avatar
squirells 06 is an unknown
well its just the stock bcs and the waste gate was not seated very tight , so i tightened it and the boost raised. and yea the coils are correct..... could the MAF be making it miss like that (only under load)?
hmmm should i just burn the car and claim it on insurance. na j/k .. but seriously
squirells 06 is offline
post #17 of 23 Old 07-26-2009, 01:14 PM Thread Starter
Last edited by squirells 06; 07-26-2009 at 01:17 PM. Reason: said the exact same thing in the above post
post #18 of 23 Old 07-26-2009, 01:35 PM
03 CrazyTaxi's Avatar
Check the coils, swap the two on the one side that you are having the misfire and if the misfired moves, it's the coilpack. Also, pick up some CRC QD Electrical Cleaner and spray out the MAF. Let it dry completely and do a hard reset of the ECU. Basically pull the negative off the battery and step on the brake for 20-30 seconds, reattach the battery cable and you should be good to go.
03 CrazyTaxi is offline
post #19 of 23 Old 07-26-2009, 01:49 PM Thread Starter
ok ill try that in a few. thanks for stickin with me on this taxi>
post #20 of 23 Old 07-26-2009, 10:21 PM
Obviously I don't mean to insult your intelligence but keep the wires going to the correct cylinder, just unplug the coil pack and move them.
I made this post a while back, and it had some helpful suggestions from all the guys:My endless Misfire... What was yours from?
It gets really, really sidetracked arguing fuel pumps and talking opensource but there are some good tips. MY current misfire is because I'm burning so much oil through my turbo seals. If I change my plugs, it goes away for a while until it fouls them up again. But you just put in new plugs so that's probably not it for you.
post #21 of 23 Old 07-27-2009, 03:51 AM Thread Starter
ok so this is what i have got to try to solve my misfire
compression test they all above 130psi
new fuel pump
new sti injectors
cantremember if i switched the coils or not
new one step colder plugs that are f-in gaped at .040 damnit now i have to take them out again
new fuel filter
so ill do that coil switch and regap the plugs tomorrow and let yll know
post #22 of 23 Old 07-27-2009, 11:08 PM
Gap should be .028
post #23 of 23 Old 07-31-2009, 07:03 PM Thread Starter
god my stupidity, yes the misfire was from an incorrect gap on the plugs. i set the gap to .28 like i was told and walah!!! the misfire is gone. you guys are badasses
Thank you one more time for everyones help it is greatly appreciated
