mbc problem - Subaru WRX Forum
post #1 of 7 Old 07-05-2004, 07:23 PM Thread Starter
T Rex is an unknown
mbc problem
Just installed mbc and its still cutting boost from 5000 to 7000 rpm is there something wrong
T Rex is offline
post #2 of 7 Old 07-05-2004, 08:19 PM
AZ-Scoob's Avatar
AZ-Scoob is an unknown
Send a message via MSN to AZ-Scoob
how much boost are you pushing? with an up & downpipe, turbo back exhaust and a mbc. I would hit the fuelcut at around 17-18psi, after adding the 255L pump and bumping the fuel pressure up 10psi, I had no problems. not the best way to go but its a start. I now have the STi injectors and a dyno tuned reflash to keep everything happy.
[I]"Winners never quit, quitters never win, those that never win or quit are idiots."[/I]
AZ-Scoob is offline
post #3 of 7 Old 07-05-2004, 09:21 PM
Tut4u2's Avatar
Images: 11
Tut4u2 is an unknown
Sounds like you don't have fuel in there.
Che
Tut4u2 is offline
post #4 of 7 Old 07-07-2004, 10:05 AM
Boo02 is an unknown
1.17Kmpc that equals 16.97psi. See for yourself http://www.sciencemadesimple.net/EASYpressure.html Set your T timer peak boost alarm at this level (assuming you have one) then adjust mbc accordingly. AZ Scoob is right, it is a fuel issue. Without changing the pump and injectors this will continue to happen...that's not good!
The best way I found to get peak boost is to roll into the throttle. On a nice streatch of road 4th or 5th gear, don't hit it just roll into it. Until I installed my dual timer did I discover this happy meduim.
Much more boost than this you are testing the limits of the stock turbo, which may not be a bad thing...Turbo upgrade.
Good luck
Boo02 is offline
post #5 of 7 Old 07-09-2004, 01:17 AM
AZ-Scoob's Avatar
ooh, turbo upgrade! good idea!!! now if I can only get the vf-22 put on before the wife finds out what I'm up to!!!!!
AZ-Scoob is offline
post #6 of 7 Old 07-09-2004, 10:21 AM
IBAUCLAPlaya's Avatar
I love it. Sneaking on new turbos w/o the spouse knowing lol
IBAUCLAPlaya is offline
post #7 of 7 Old 07-11-2004, 01:20 AM
AZ-Scoob's Avatar
how about modifying your stock injectors at the dinner table? did that the other day! boy did I get in trouble!! oh well, gotta get to figuring how to reflash my own ecu. (maybe I can do that in the living room???)
AZ-Scoob is offline
