MAF Problem - Subaru WRX Forum
post #1 of 5 Old 07-02-2010, 03:18 AM Thread Starter
rodrigoferrari's Avatar
rodrigoferrari is an unknown
Send a message via MSN to rodrigoferrari
MAF Problem
Hi,
My car was using a cold intake system from K&N, now I put back the OEM boxed filter intake but the car started to fail and the Cruise light start to blink with Check Engine on all the time.
I already took of and cleaned with MAF Cleaner but the problem still strong.
When idling if I disconnect the MAF the engine DIE, if I plug again it wants to die and sometimes die.
What can be? Just a ODB scan can clear the error or this is a auto clean error when the MAF come back to work?
I already tried to find on the Internet to buy another one, but I can't find.
Can anyone help me with this issue? Or indicate where I can buy I new one.
DENSO 22680AA380
Thank you.
rodrigoferrari is offline
post #2 of 5 Old 07-02-2010, 03:42 AM Thread Starter
Originally Posted by rodrigoferrari View Post
Hi,
DENSO 22680AA380
Thank you.
MAF Problem.
post #3 of 5 Old 07-03-2010, 08:13 AM
03stg2wrx's Avatar
03stg2wrx is an unknown
you probably mounted the maf backwards, try mounting it turned the other way
03stg2wrx is offline
post #4 of 5 Old 07-06-2010, 11:25 AM
What CEL code did you get ?
post #5 of 5 Old 07-06-2010, 11:51 AM Thread Starter
Was two codes, one for MAF and another for IAT, I don't remember because I already cleared both with Dashhank a few days ago. Now it is working, I put for 30 minutes de MAF sensor inside 100% ethanol...
