-   -   MAF Problem (http://www.wrxtuners.com/forums/f72/maf-problem-29056/)
rodrigoferrari 07-02-2010 03:18 AM
MAF Problem
Hi,
My car was using a cold intake system from K&N, now I put back the OEM boxed filter intake but the car started to fail and the Cruise light start to blink with Check Engine on all the time.
I already took of and cleaned with MAF Cleaner but the problem still strong.
When idling if I disconnect the MAF the engine DIE, if I plug again it wants to die and sometimes die.
What can be? Just a ODB scan can clear the error or this is a auto clean error when the MAF come back to work?
I already tried to find on the Internet to buy another one, but I can't find.
Can anyone help me with this issue? Or indicate where I can buy I new one.
DENSO 22680AA380
Thank you.
rodrigoferrari 07-02-2010 03:42 AM
[quote=rodrigoferrari;247191]Hi,
DENSO 22680AA380
Thank you.[/quote]
MAF Problem.
03stg2wrx 07-03-2010 08:13 AM
you probably mounted the maf backwards, try mounting it turned the other way
pzr2874 07-06-2010 11:25 AM
What CEL code did you get ?
rodrigoferrari 07-06-2010 11:51 AM
Was two codes, one for MAF and another for IAT, I don't remember because I already cleared both with Dashhank a few days ago. Now it is working, I put for 30 minutes de MAF sensor inside 100% ethanol...
