Low RPM Missfires - Page 2 - Subaru WRX Forum
post #16 of 22 Old 07-15-2011, 11:20 AM
Running rich or burning oil or almost anything.
What color ?
When it's cold or hot ?
Is the car warmed up ?
Too many factors
FYI.......Start your own thread for more assistance.
post #17 of 22 Old 07-16-2011, 04:20 PM Thread Starter
LewdWRX is an unknown
Okay, the plugs are in. Wasn't that bad...I expected worse from what I read on these forums. Anyway, misfires are better, but not non-existant. It is MUCH harder to make it misfire. I have only been able to make it happen sitting still in the parking lot and VERY lightly comming off idle.
Otherwise she runs better than ever!. All plugs look equal whitish. That is a good sign of engine heath I take it.
I will check the maps soon.
09 WRX K&N Typhoon Walbro 255 SPT BG AEM UEGO Tactrix2.0 XPT Stocks + Winter wheels w/Dunlop WS 3D
LewdWRX is offline
post #18 of 22 Old 07-18-2011, 11:09 AM
Its always going to have some aversion to low rpms. Unless you get better headers. Even my Unequal length GT Spec headers killed my stumble down low, but it also still killed some rumble.
post #19 of 22 Old 07-22-2011, 12:48 PM Thread Starter
Okay, so I have reviewed the Tip in Enrichment A and B tables from my current map and my stock map. Both are identical, so that shouldn't be an issue.
The problem seemed to have smoothed out after the plugs, but it is still there. I noticed it seemed worse today. Just thinking about all factors....I wonder if it's temp related. It is VERY hot right now and it was the other week when I made this post.
I drive my car for business alot and sometimes find myself idling for extended periods. This is when I notice it most and the engine is heat soaked at those times.
Otherwise it runs better than ever. Maybe I should just not worry about it:/
LewdWRX is offline
post #20 of 22 Old 07-22-2011, 02:26 PM
Switch the coils around. See if you get the same mis-fires
post #21 of 22 Old 07-22-2011, 03:48 PM
Huh that's odd. Could be your IAT I suppose. Also the tip-in enrichment tables should be different to take into account the intake your running. Then again it's probably one of those odd issues where it didn't matter I guess.
post #22 of 22 Old 09-29-2015, 07:06 PM
dtodt13 is an unknown
reviving an old post sorry. im also having misfires now. im in the process of diagnosing it but i just want to know what parameters you log to see misfire information? mine seem to be at low rpms and at high rpm under boost. but seeing it on paper (screen) is always good
dtodt13 is offline
