Low Boost :( after returning to stock solenoid - Subaru WRX Forum
post #1 of 6 Old 03-14-2011, 03:26 AM Thread Starter
lifelike is an unknown
Hi all,
I have a My02 Aus Spec WRX wagon and recently installed a MBC before i researched furthur and found out they are S$#T!! lol. After the car going in to limp mode i have returned to the stock solenoid but boost doesnt seem to be going over 9psi... I then flash tuned a stage 2 xpt map to my car but still the same 9psi, any ideas?
Cheers!
lifelike is offline
post #2 of 6 Old 03-14-2011, 05:23 AM
Has to be hooked up incorrectly. Check your connections/hoses
post #3 of 6 Old 03-14-2011, 07:37 AM
wagonracer's Avatar
Make sure that the restrictor pill is in there too. You won't get to full boost without it.
wagonracer is offline
post #4 of 6 Old 03-14-2011, 07:15 PM
Hondafan's Avatar
9 psi is the magic number for wastegate turbo pressure. Did you reset the computer's learning after you flashed it? I know that sounds redundant, but my car retained memory on one of my reflashes. . . Or at least it didn't boost again until I reset the ECU learning.
-Brad
Hondafan is offline
post #5 of 6 Old 03-15-2011, 01:26 AM Thread Starter
MMM no restrictor pill, that'll do it! I removed that part of the hose when i fitted the MBC, and no longer have it... now just need to find another, any ideas on where to pic one up?
cheers guys
lifelike is offline
post #6 of 6 Old 03-15-2011, 05:46 PM
Hondafan's Avatar
Direct from Subaru. Dealer charges like, 2 dollars or less.
-Brad
Hondafan is offline
