Car: 2004 WRX
Recently, the passenger side DRL went out. Low beams still worked.
I changed it out with a cheapo brand called EiKO. It has a 60-day warranty.
Now it works, but the light is dim. It is really sunny outside so I'm not 100% sure, but the other side (driver's) is noticeably twice as bright.
So I tested out the high beams, and the whole passenger side lights just turned off, while the driver's side was high beam.
Turning off the high beams would go back to low beams fine, with the passenger side still being real dim.
I was thinking it was maybe an electrical problem. I'm not sure how long the high beam problem has been going on since I never check.
