Lots of white smoke after idling - Subaru WRX Forum
post #1 of 10 Old 10-08-2011, 08:13 PM Thread Starter
mfarnham's Avatar
mfarnham is an unknown
Basically I've noticed a lot of white smoke coming out my exhaust after I sit and idle for a few minutes. If I'm not mistaken, white smoke means coolant. What could be leaking that it's getting in my engine?
mfarnham is offline
post #2 of 10 Old 10-08-2011, 09:41 PM
When do you notice it most? Is the car still cold or up to temp.?
post #3 of 10 Old 10-08-2011, 09:47 PM Thread Starter
mfarnham's Avatar
Up to temp. And like I said, I notice it after idling for a few minutes.
mfarnham is offline
post #4 of 10 Old 10-08-2011, 09:48 PM
Oil seal in the turbo is going bad would be my guess...
post #5 of 10 Old 10-09-2011, 09:37 AM Thread Starter
mfarnham's Avatar
If thats the case, then I either need a rebuild or a new turbo, right?
mfarnham is offline
post #6 of 10 Old 10-09-2011, 04:38 PM
wagonracer's Avatar
I experienced the same thing when my original turbo got up to about 90K miles. I lived with it for a couple of years, monitoring fluid levels closely. Obviously not closely enough as I spun a rod bearing at 137K A newer turbo went on the new engine. My point is, you do not need to panic. Use it as an excuse to plan ahead for a turbo upgrade
Cullen
wagonracer is offline
post #7 of 10 Old 10-09-2011, 05:20 PM
You have a PM.
post #8 of 10 Old 10-09-2011, 07:18 PM Thread Starter
mfarnham's Avatar
Keith
Thanks for the advice.
Cullen
What fluids are potentially being burnt that I should keep an eye on? Oil and coolant?
mfarnham is offline
post #9 of 10 Old 10-09-2011, 08:05 PM
Oil, unless the center housing is cracked then coolant, but I doubt that is the case. A little oil smokes ALOT!!!
p.s. If you want to avoid down time while your getting yours fixed let me know. I have a spare lying around here somewhere...
post #10 of 10 Old 10-09-2011, 08:10 PM Thread Starter
mfarnham's Avatar
I definitely can't afford to fix it right now. I'll keep that in mind though. Thanks for the help.
mfarnham is offline
