Limp Mode..Needing some input please!! - Subaru WRX Forum
post #1 of 6 Old 06-16-2012, 03:20 PM Thread Starter
rotheee's Avatar
rotheee is an unknown
Question Limp Mode..Needing some input please!!
Make things short, been in limp mode for 2 months now(the day i meet the tuner to get tuned for an 02 Wideband install) I've replaced MAF sensor, fuel filter, tried a different set of spark plugs. Here recently just the past week i decided to spray out my Prodrive 3-port BCS, to try to clean it and see if that was the issue. Well make the story short, i drove to work after doing it and i was able to hit my boost target, 22psi.. When i got off work 9 hours lately i was driving home and car went back into limp mode?! . I've tried cleaning it out 2 or 3 times since then and using silicone lubricant, wd-40 and it still didnt work. So i decided to order myself a new boost solenoid. Grimmspeed 3-port. Installed it earlier today and it didnt fix my problem!!
What could be the issue here? Wastegate, turbo? or wiring?
Just seems odd that the first time i sprayed it out it worked and now it took a shit again, even with a new bcs.
Any input would be helpful
rotheee is offline
post #2 of 6 Old 06-16-2012, 05:40 PM
bad grocerygetter's Avatar
You are tuned for the 3 port bcs right?
Kevin.
bad grocerygetter is offline
post #3 of 6 Old 06-16-2012, 06:29 PM
No CEL's?
BTW...When you clean a BCS, you need to use something less "invasive" like MAF cleaner or the likes.
What are you hitting on this "limp mode"?
post #4 of 6 Old 06-17-2012, 10:01 AM Thread Starter
rotheee's Avatar
yeah the car was already tuned for a Prodrive 3-port, just replaced it with a grimmspeed cause i thought it was my problem.
No CEL's?
Yes i now have new codes also. I included a screenshot of learning view. Thanks for the heads up about cleaning the bcs. I am only hitting 13psi then going to limp mode, limp mode being 6-7psi.
rotheee is offline
post #5 of 6 Old 06-17-2012, 06:45 PM
You should at least be hitting WG pressure of 9 IINM.
post #6 of 6 Old 06-17-2012, 10:58 PM Thread Starter
rotheee's Avatar
Which is?? when the wastegate should actuate?
rotheee is offline
