Knocking Noise - Subaru WRX Forum
post #1 of 4 Old 05-14-2014, 03:19 PM Thread Starter
H0bb1tM1ndTr1x's Avatar
H0bb1tM1ndTr1x is an unknown
Knocking Noise
On my way to work today my car started making an odd noise that sounded like someone knocking on my roof/dropping an infinite amount of acorns on the roof. Only way to describe it really.
I drive an '02 WRX and have already tried a couple things, my main thought was the spoiler had come loose but I tied it down and still hear it.
So here is the run down:
It sounds like it might be directly above the front seats somewhere. The car still runs exactly as it did yesterday, no warning lights, no other noises, and still takes off like a rocket. The only problem is the noise is quite annoying and it starts its continuous knocking around 35mph. Lower than that and I need to be taking a turn or do some swerving, almost like something in the roof is dangling around.
I plan on checking the windshield seal once I'm out of the office in a couple hours as someone offered a wind theory, which was part of my spoiler theory.
Any thoughts?
H0bb1tM1ndTr1x is offline
post #2 of 4 Old 05-14-2014, 06:11 PM
That's the 1st time I've heard of roof noises. Please keep us updated if you find the cause.
post #3 of 4 Old 05-14-2014, 07:33 PM
arcticscythe's Avatar
You may also want to tighten down your crossbars, and if you have a auto dimming mirror check and see if the wire is loose, mine made a light tapping noise when i was going down the 405 so I rubber banded it to the post.
- Jason
arcticscythe is offline
post #4 of 4 Old 05-15-2014, 09:15 AM Thread Starter
I found the culprit. Apparently the rubber seal along the windshield was popping up once I got enough wind resistance and was somehow, I blame voodoo, sneaking back into it's little space so I didn't notice it at first.
Simple problems. >.<
