just bought a used 02 wrx, its very slow, what could be wrong? - Subaru WRX Forum
post #1 of 7 Old 03-01-2003, 12:02 AM Thread Starter
duba-u-R-x is an unknown
it hesitates alittle hear and there, and it feels like it only has like 2 lbs of boost. ?
duba-u-R-x is offline
post #2 of 7 Old 03-14-2003, 11:12 AM
WhatleyWRX is an unknown
"feels" like it only has 2lbs of boost? You'll need to lay down a little more info to get much help here. Does it have any mods? Check to see if anything isn't hooked up like the factory boost lines, do you have any CELs?
Need more Info.
Whatley.
WhatleyWRX is offline
post #3 of 7 Old 03-14-2003, 02:05 PM
hypnoticwrx is an unknown
How many miles does it have? Does it hesitate when you lift off of the gas? or when on the gas? Check the grounds and the spark plugs. Thanks.
Ivan
hypnoticwrx is offline
post #4 of 7 Old 03-20-2003, 03:06 AM
wrxratedII is an unknown
sound like some one may have had a boost controler on it and removed it and forgot to hook up the boost solenoid, it is located under that little black cover on the passanger side just infront of the strut housing, it has two twist locks that hold the cover on, there should be a 3mm hose going from that vavle to the boost port on the turbo outlet tee, that hose will aslo go to the waste gate. make sure that the low pressure side of the T is going to the boost sol, and the high pressure side to the waste gate.
wrxratedII is offline
post #5 of 7 Old 04-10-2003, 04:29 PM
rexwagonee is an unknown
get some gauges, it will help you diagnose your problems.
rexwagonee is offline
post #6 of 7 Old 04-13-2003, 05:15 PM
<(-_-)> is an unknown
Send a message via AIM to <(-_-)>
If nothing else, just get a boost gauge from pep boys or somethin for like 50 bux, it'll give you exactly what boost your runnin at. My money is on a bad plug/wire but why on such a new car? hmm..
<(-_-)> is offline
post #7 of 7 Old 04-15-2003, 03:39 PM
P0S3R is an unknown
This sounds probable.
P0S3R is offline
