invidia up pipe and 02 sensor problems! - Subaru WRX Forum
post #1 of 8 Old 03-27-2010, 01:47 PM Thread Starter
sivart08 is an unknown
ok i read a bunch of other threads and i cant find an answer... i just put on an invidia uppipe and now i have a cel on that says its my 02 sensor.. if i get a new 02 will the cel still come on since i have a catless system??
sivart08 is offline
post #2 of 8 Old 03-27-2010, 03:11 PM
Is it your front or rear O2? If it is your front it could just be unplugged, did you remember to plug it in?
nagyhead is offline
post #3 of 8 Old 03-27-2010, 03:33 PM
VD5505's Avatar
I would do that and reset your ECU
2003 WRX Hybrid build,
Brian
VD5505 is offline
post #4 of 8 Old 03-27-2010, 05:30 PM Thread Starter
its the front one, pre cat...
sivart08 is offline
post #5 of 8 Old 03-28-2010, 08:34 AM
Is it plugged in?
nagyhead is offline
post #6 of 8 Old 03-28-2010, 03:40 PM Thread Starter
lol yea i had it plugged in.. i got one i had to wire myself.. so now im just gonna try one that is a direct oem replacement.. but my question was will there still be a cel since i dont have a cat in the uppipe?
sivart08 is offline
post #7 of 8 Old 03-29-2010, 02:19 PM
There shouldn't be a cel because the front o2 is before the cat. You may get a EGT code though if you eliminated that, which should be done anyway because the probe that goes into the up-pipe has been know to snap off from the heat and get sucked into the turbo.
nagyhead is offline
post #8 of 8 Old 03-29-2010, 08:00 PM Thread Starter
o ok thanks for the info...
sivart08 is offline
