Idling issues - Subaru WRX Forum
post #1 of 13 Old 04-12-2010, 02:11 AM Thread Starter
suby_doo's Avatar
suby_doo is an unknown
Send a message via Yahoo to suby_doo
Idling issues
My car has a hard time keeping idle; some days its fine other days its crap..... i can be driving with partial throttle and it will start to hesitate feels like its choking..... Could it be my TGV delete or the IACV is dirty or bad........
suby_doo is offline
post #2 of 13 Old 04-12-2010, 08:02 AM
mfarnham's Avatar
mfarnham is an unknown
As far as I know, a TGV delete shouldn't cause that kind of problem. No CEL's? No sure what the IACV is, but my first thought would be the spark plugs. How old are they?
mfarnham is offline
post #3 of 13 Old 04-12-2010, 08:04 AM
Cleaning And Reattaching The IACV (Idle Air Control Valve)
Ryan
2009 STi - Cobb Stage 2
VisiX is offline
post #4 of 13 Old 04-12-2010, 08:29 AM
I suppose my first question would be what mods were done and who tuned the car?
post #5 of 13 Old 04-12-2010, 12:10 PM Thread Starter
suby_doo's Avatar
IACV IS THE idle air control valve, spark plugs are only a month old put the NGK BKR7EIX in there and car has tbxs tbe, short ram intake crank pulley, intercooler with perrin y-pipe, tbxs bov, tbxs fuel rails, tgv delete on a utec stage 1...... and to add when the idle does go all wack it starts to smell like raw fuel
suby_doo is offline
post #6 of 13 Old 04-12-2010, 12:54 PM
mfarnham's Avatar
That's probably your problem right there; you have all those mods on a simple stage 1 tune. You really should have a custom map with those parts. Also, BOVs are known to cause rough idling/stalling.
mfarnham is offline
post #7 of 13 Old 04-12-2010, 02:03 PM Thread Starter
suby_doo's Avatar
true the only thing i can say is that the car just recently started doing this i have been on that tune with those parts for a good while already and never had problems before..... and to add i took the car to autozone to check the dtc's and i knew about the tgv codes but two new ones came up P1446(fuel tank sensor control valve circuit low) and P1491 (crankcase ventilation blowby function problem.... have no idea how to fix those
suby_doo is offline
post #8 of 13 Old 04-14-2010, 08:43 AM
mfarnham's Avatar
No idea how to fix those either. I would take it to your mechanic if possible. The first code sounds like maybe engine wasn't getting enough fuel or something.
mfarnham is offline
post #9 of 13 Old 04-14-2010, 11:47 AM
Check the gas cap? How about the vaccum hoses? Sounds like a loose vac line.
Ryan
VisiX is offline
post #10 of 13 Old 04-14-2010, 11:55 AM
He and I looked for vac leaks and they are all over the place.
Thought he bought new gaskets ??? Nathan ?
post #11 of 13 Old 04-14-2010, 12:12 PM Thread Starter
suby_doo's Avatar
got the new gaskets on the intercooler..... and moved that vacuum hose over like you said but now i got those two codes and it does feel like the car is not recieving enough gas.... and i called gillman subaru and they just gave me the run around they wouldnt let me talk to a mechanic they told me they dont have any subaru technicians but if i wanna bring the car by for a diagnostics and pay 90 bucks for what autozone tells me for free
suby_doo is offline
post #12 of 13 Old 04-14-2010, 12:27 PM
I just helped a friend here last month and it ended up being the fuel filter (which you told me is in the bay ONLY ??)
His was in the tank mounted on the pump. When you say it smells like fuel all over the place it makes me think the pump and filter.
Get that IACV done..... Did you put the fuel rails in ? Where does it smell like fuel the most ?
Ask a mod to combine your 2 posts
post #13 of 13 Old 04-14-2010, 12:49 PM Thread Starter
suby_doo's Avatar
no someone did the rails for me...... smell comes from the bay not the cabin it just enters the cabin through the vents.....
suby_doo is offline
