-   -   idler pulley? (http://www.wrxtuners.com/forums/f72/idler-pulley-33679/)
thekamikaze kid 03-05-2013 04:16 PM
idler pulley?
so lately i have been getting a noise from under my hood for the first few minutes while the car is idling. after a while it goes away. it sounds like it is coming from one of the pulleys attached to the fan belt. its not a high pitched squeel oand the belt isnt slipping, but it sounds like i can hear the pulley spinning much louder. I had a friend of my dads look at it said it could be the idler pulley. has anyone had this problem? any thoughts? should i take it to get looked at or could it be the weather? :confused: I couldnt get a good vid of it maybe i can later, need to use diff camera.
the RIOT act 03-05-2013 04:25 PM
idler pulley?
Sounds like it being the idler if you can specifically hear it coming from the pulley, and not just the general vicinity. Pulleys have bearings though which will always fail eventually...nothing to worry about. But it could also be a bad belt, alternator, or steering pump as well. But if you hear it at the pulley def start there a it's the cheapest fix. Either a belt or pulley is WAY more likely your problem though. Idlers are cheap though and pretty easy to replace. I'd def recommend changing the belts along with the bad/other idler pulleys. I always do them all at once. It'll save brain damage later lol...
thekamikaze kid 03-05-2013 04:49 PM
yah, im glad to hear that, i was hoping it would be a cheap fix:D i will prob just replace the whole thing. thanks riot!
the RIOT act 03-05-2013 05:17 PM
idler pulley?
Yeah if you hear the noise right at the pulley def start there. Make sure you at least check your belts and replace if needed. But if there's more than 1 idler (which I dont think there is on yours) I'd replace that also since you're in there and have the belts off. Not sure how many idlers/tensioners you have though. Pretty sure it's 1/1 on the 03'
General-Leo 03-06-2013 03:06 AM
Not trying to hate, but this man wants to make sure that you check your belts. I feel like I read it like 4-5 times ROFL
[quote=the RIOT act;291368]Sounds like it being the idler if you can specifically hear it coming from the pulley, and not just the general vicinity. Pulleys have bearings though which will always fail eventually...nothing to worry about. But it could also be a bad belt, alternator, or steering pump as well. But if you hear it at the pulley def start there a it's the cheapest fix. Either a belt or pulley is WAY more likely your problem though. Idlers are cheap though and pretty easy to replace. I'd def recommend changing the belts along with the bad/other idler pulleys. I always do them all at once. It'll save brain damage later lol...
[color=gray]Sent from [url=http://www.autoguide.com/mobile]AutoGuide.com App[/url][/color][/quote]
the RIOT act 03-06-2013 05:33 AM
idler pulley?
I'm trying to upsell him General LMAO
