Idle Issue - Subaru WRX Forum
post #1 of 6 Old 12-17-2009, 09:10 PM Thread Starter
Idle Issue
Hey forum members, ok so here it goes after I just got my car retuned at the beginning of the week I've noticed that whenever you are coming to a stop and just press the clutch in the car 9 times out of 10 stalls but when it's idling it has a smooth idle and it feels like normal powerwise...I was wondering if any of you out there have any suggestions at what this might be???
post #2 of 6 Old 12-17-2009, 09:13 PM Thread Starter
forgot to mention I also just installed a Turbo-XS BPV...is it possible that the BPV needs adjustment?
post #3 of 6 Old 12-17-2009, 11:31 PM
Is it set to full recirc? hybrid? or full atmosphere?
post #4 of 6 Old 12-18-2009, 01:01 AM Thread Starter
It's a full recirc...but as I've been sitting here pondering I'm pretty sure I might have a torn turbo inlet...tomorrow when I pull my CEL codes if theres a system lean code I'm going to tear down the intake system
post #5 of 6 Old 12-18-2009, 10:43 PM
Good luck and I hope you find the problem
post #6 of 6 Old 01-17-2010, 06:35 PM
busadave is an unknown
idle issue
just spit balling here,but did you happen to check your neutral safety switch? Ive seen this happen before.Good luck.
busadave is offline
